Nobody is Perfect
« back to Coffee Lounge forum
Forum topic by MrRon posted 03-27-2015 04:30 PM 1091 views 0 times favorited 10 replies Add to Favorites Watch
View MrRon's profile
MrRon
5264 posts in 3481 days
03-27-2015 04:30 PM
The title says it all, but I will add: “We should always work toward being perfect”, although we will never reach it. I hear so many people say; “it’s good enough”. It’s never just good enough. If you work for a passing grade, that’s what you may get. If you work for an “A”, you may not get an “A”, but you might end up with a “B” which is much better than “just passing”.
10 replies so far
View nailbanger2's profile
nailbanger2
1041 posts in 3381 days
#1 posted 03-27-2015 04:36 PM
Aim small, miss small.
-- Wish I were Norm's Nephew
View DIYaholic's profile
DIYaholic
19743 posts in 2913 days
#2 posted 03-27-2015 07:11 PM
Ron,
I agree…. I also disagree!!!
I always try to do my best, when it matters!
“When” depends upon the project….
Is this a gift?
Is it a shop project?
Is it an experiment/prototype/skills building project?
Is it a down & dirty jig?
Does it need to be done…. yesterday!!!
View willie's profile
willie
534 posts in 2692 days
#3 posted 03-27-2015 08:58 PM
Build it like you were building it for yourself. If you’re happy, the recipient should be happy. If it’s not good enough for you, why would it be good enough for someone else?
-- Every day above ground is a good day!!!
View Picklehead's profile
Picklehead
1053 posts in 2167 days
#4 posted 03-27-2015 09:54 PM
I try to practice on everything I build, even if it’s 2×4 stuff, so that when it counts I’ll have the experience/skills. Gotta be careful that this doesn’t prevent getting the “quick and dirty” stuff done, though. It’s a balance. Besides, if you’re perfect, there’s nowhere to go but down.
-- Quote from ebay tool listing: " Has nicks and dings wear and tear dust and dirt rust and pitting but in good working condition"
View Texcaster's profile
Texcaster
1286 posts in 1912 days
#5 posted 03-27-2015 10:10 PM
Ron,
Is this a gift?
- DIYaholic
I have to agree with Randy, sometimes good enough will do.
-- Mama calls me Texcaster but my real name is Mr. Earl.
View Gerald Thompson's profile (online now)
Gerald Thompson
1142 posts in 2472 days
#6 posted 03-27-2015 11:48 PM
The enemy of damned good is just a little bit better.
-- Jerry
View JoeinGa's profile
JoeinGa
7740 posts in 2245 days
#7 posted 03-28-2015 12:16 AM
”Set your goals low, they’re easier to achieve.”
Author unknown
View Dark_Lightning's profile
Dark_Lightning
3367 posts in 3347 days
#8 posted 03-28-2015 12:45 AM
I’m currently building a tool chest. I have a really small table saw that I can’t cut the carcase pieces out with. So, I’m down to a framing square and clamps on the top of the table saw, then using a router to trim the edges square and to length. My tolerance for out of square is to use a .004” feeler gauge to verify it. That sounds tight, but tolerances build as the errors build. I also had to true up my framing square, as it was slightly out. I have the end plates and the lid and bottom cut out to size; the rest can be run through the table saw. Took me a couple of hours. This is about 5 minutes work with a table saw of the proper dimensions. It won’t be perfect when it is done, but the drawers will slide easily, and hold all the tools. And, it will look nice. That’s all the perfect that I need.
-- Random Orbital Nailer
MrRon
#9 posted 03-28-2015 05:01 PM
I don’t recall where I saw this, but there was a saying that read: “A man can have a menial job, like sweeping a floor, but he does it to the best of his ability.” This is something I subscribe to; always give more than 100%. The result is less failure and self satisfaction, and admiration from others.
Craftsman on the lake
2845 posts in 3676 days
#10 posted 03-28-2015 05:26 PM
As I continue to make more and more stuff and learn, I always preface it by saying that this is best I can do at this time. Often it actually is!
