Making Tenons on large pieces
Forum topic by longboarder posted 06-27-2009 07:46 PM 1267 views 0 times favorited 5 replies Add to Favorites Watch
View longboarder's profile
29 posts in 3200 days
06-27-2009 07:46 PM
Topic tags/keywords: question
I am building a headboard that has rails (horizontals) that are 3/4×5”x 60” long which is hard to do on my table saw. Thinking about doing loose tenons and just mortising these pieces and also mortising the Styles(verticals).The Styles I can do with my mortising machine as I can lay them horizontally and mortise but the rails are too long and stand up to do them on my mortising machine. Any advice would be appreciated. I don’t want to have to by a new machine right now but any jigs out there. Thanks so much in advance.
5 replies so far
View SCOTSMAN's profile
5849 posts in 3520 days
#1 posted 06-27-2009 08:11 PM
Best advice I can give it to do them with a router with an appropriate bit and then square off the round edges by hand or round the tenons.Alistair
View brianinpa's profile
1812 posts in 3658 days
#2 posted 06-29-2009 02:42 AM
I use my RAS with a dado stack set. Works great. If you don’t have a RAS, then the router would be my suggestion.
View PurpLev's profile
8534 posts in 3583 days
#3 posted 06-29-2009 04:13 AM
good time to make a sled for the table saw.
otherwise – the router would be my second choice. build some sort of a fixture that will house the end of the rails, and will allow the router to slide on (if you use the rail as the base for the router – once you start taking off material ,you’ll be left with very little base that might not be stable) – then set a straight edge that will define the edge of the tenon, and route down the edge of the rails till you hit that straight edge.
of course you could always also use a handsaw, and planes/chisels.
View pickles's profile
68 posts in 3348 days
#4 posted 06-29-2009 04:09 PM
I think the suggestions above are for making integral tenons. I would clamp the rail in my tail vise at an angle so I could reach the end and then use a router and fence setup to make a slot mortise and clean up rounded corners with a chisel.
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3221 days
#5 posted 06-29-2009 04:48 PM
The tenon could be done on a table saw. Use a dado set and a cross cut sled. That way you don’t have to stand it on end like you would with a tenoning jig.
