Shaper--how far can I reduce a cutters bore?
Forum topic by SirIrb posted 03-27-2015 03:56 PM 624 views 0 times favorited 2 replies Add to Favorites Watch
View SirIrb's profile
SirIrb
1239 posts in 1133 days
03-27-2015 03:56 PM
I am looking at a 1/2” shaper. If I have 3/4 bore cutters I feel it is safe to use reducers and spin them. How far would you go? 1” and reduce it to 1/2? I have gone 1.25 to 1 before and 1.125 (old machine) to 1”. Or is your greatest limiting factor cutter weight?
I really hate buying a 1/2 machine but the price is good.
2 replies so far
View Bluepine38's profile
Bluepine38
3379 posts in 2988 days
#1 posted 03-27-2015 04:42 PM
I am not an expert, I bought a 1/2” shaper for $50 and rebuilt it for home hobby shop use, Grizzly sells the
bushings and I have no problem using 3/4” cutters. I have a friend that has two 1” shapers with power
feeders, if you want to do anything more than small hobby shop work, do not buy the 1/2” shaper, if you
have used the larger shapers, you know the limits of the small one and are going to have to answer your
own question on whether or not it can work for you.
View Oughtsix's profile
Oughtsix
42 posts in 1077 days
#2 posted 03-29-2015 03:57 AM
It is not the diameter of the cutters bore you need to worry about it is the outside diameter of the cutter that you need to worry about. I wouldn’t want a cutter with an outside diameter of more than a couple inches on a 1/2” spindle shaper regardless of the bore diameter of the cutter.
