12" Crescent jointer for sale--$300!
Forum topic by TedSherman posted 03-26-2015 11:07 PM 3623 views 0 times favorited 6 replies Add to Favorites Watch
View TedSherman's profile
TedSherman
18 posts in 1068 days
03-26-2015 11:07 PM
Topic tags/keywords: jointer
http://gadsden.craigslist.org/tls/4893865306.html
Thought some of you might be interested in this jointer.
Just got these details from the seller:
“Table length: 5ft. long x 16 inches wide. Height: 35 inches from floor to table top edge. Widest part of machine is 44 inches. Unknown mfg. date mid 40’s- late 50’s. Can’t find the serial number but hundred percent sure it is on it, 12” Crescent Wood Jointer great shape nothing wrong with the equipment. Removed from plant due to remodel project in use at time of removal. Heavy duty industrial jointer / 3 phase/ 3 HP/3460 RPM / 440 volts, has all guards, new disconnect, new push button on/off switch, all wired ready to use.”
-- Ted
View Deano56's profile
Deano56
91 posts in 1100 days
#1 posted 03-27-2015 02:08 AM
thats a strange looking one, I thought I have seen them all. Heres a nice 12” DDM Northfield, latter model than the one you are thinking about. I’d like to know what it will go for, I would suspect around 1200.00 http://chicago.craigslist.org/nwc/tld/4949804866.html
-- Deano
View bigblockyeti's profile
bigblockyeti
4992 posts in 1627 days
#2 posted 03-27-2015 03:10 AM
That Crescent is certainly different from any others I’ve seen. I have a 12” Crescent and it looks similar in build to the Northfield mentioned above. $300 does seem like a pretty good deal if it can be made to work. I know if for whatever reason I did decide to sell mine, it would be priced more than the Northfield, but it does have a single phase belt drive motor, updated ball bearings and the gibbs with bolts and knifes are all there.
View Rob's profile
Rob
704 posts in 2978 days
#3 posted 03-27-2015 03:51 AM
<droool>
-- Ask an expert or be the expert - http://woodworking.stackexchange.com
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1482 days
#4 posted 03-27-2015 04:03 AM
You have to plane from left to right,and the guard blocks your way as it opens?seems weird to use,love to have a planer for 300.00 just not sure on that one.plus I don’t have 3 phase 440.
Deano56
#5 posted 03-27-2015 04:05 AM
the Northfield one above is ball bearing, too bad on the three phase
-- Deano
TedSherman
#6 posted 03-27-2015 04:09 AM
I ended up getting the older Craftsman 6 1/8 ” I mentioned the other day—will post pics tomorrow. Got it for $100.
-- Ted
