Tennis Elbow
Forum topic by almostsquare posted 155 days ago 263 views 0 times favorited 16 replies Add to Favorites Watch
View almostsquare's profile
almostsquare
16 posts in 158 days
155 days ago
My tennis elbow has had a huge impact on my turning time. I have tried different positions but nothing seems to help. Any advice would be welcome.
-- Kelly in Canton
View VinnieP's profile
VinnieP
30 posts in 220 days
155 days ago
I’m not a doctor, but I have dealt with tendonitis in my elbow a lot from playing baseball. I don’t think different positions are going to help. What I have done in the past is put pressure on the tendon with some athletic tape. Start the tape on the top side of your forearm just below the bend in your elbow. Then wrap it half way to three-quarters around making it as tight as you wish. I hope this helps you out.
View tuchuxvarg's profile
tuchuxvarg
5 posts in 240 days
155 days ago
mom had tennis elbow years ago- she had a brace/wrap exactly like vinnie is describing….however it was one peice and attached with velcro….i think the sell them in the pharmacy..something like this.. http://www.americarx.com/Products/2106.html
jeff
-- Strength Honor Courage
almostsquare
155 days ago
Yeah, tried that too. Do you think maybe I am just getting old?
By the way, I really like your table saw setup.
Thannks,
-- Kelly in Canton
View MrWoody's profile
MrWoody
285 posts in 673 days
155 days ago
Almostsquare; I have severe Tennis elbow. When I get a flare up, I don’t use tools at all.
Turning has never bothered it. Have you turned for a long time? If not I’m wondering about your lathe height and the grip you use on your tools. Are you gripping them tightly?
-- If we learn from our mistakes, I'm getting a fantastic education.
View SCOTSMAN's profile
SCOTSMAN
2244 posts in 483 days
155 days ago
Here’s maybe the cause of the trouble are you sure your lathe is at the correct height? When standing side on with the lathes bed you’re lathe should come up to the level of your elbow not above or below. You may have even fluid in the elbow which will take time to heal don’t push things check this out and see if the lathe height is problematic or not.Alistair
View pommy's profile
pommy
978 posts in 590 days
155 days ago
mine flares up when i have to much brandy that may be the cause lol…...
Andy
-- cut it saw it scrap it
almostsquare
155 days ago
I have been turning for about a year. I am in the process of raising the height of my lathe and also adding some weight. Now that I think about it, I do believe that it may be to low.
Working in a steel manufacturing plant I was able to get my hands on a piece of steel that is 1” X 12” X 48” and weighs 163 pounds. That should keep things from jumping around when I get out of round material in there. It will also raise the lathe up some so maybe this will help. I intend on putting the steel between the lathe and leg set.
Thanks for the good advice this afternoon. Oh by the way…It’s 102 degrees here today!
-- Kelly in Canton
SCOTSMAN
155 days ago
That’s brandy elbow not tennis elbow.
SCOTSMAN
155 days ago
Kelly it makes a major difference believe me I had it also keep well . as said stand with your arms down by your side not up and your elbow at this height should be level with the lathe bed then you’ll be fine.Alistair
View TopamaxSurvivor's profile (online now)
TopamaxSurvivor
3063 posts in 574 days
154 days ago
I have have golfer’s elbow from the curl motion puling wire for 40 yrs. It’s just on the other side of the joint. When it starts acting up, I stick my hand straing out locking the elbow joint. Pull straigth back on the ends of your fingers with the other hand for at least 1 minute, the minute or more is important. I goes away after doing that a few times a day for a few days.
17044 posts in 475 days
154 days ago
Some times I have bent elbow. sorry about that.
almostsquare
152 days ago
As my Dad always says: Some projects require extensive lubrication. Same goes for making Chili.
-- Kelly in Canton
View rhett's profile
rhett
160 posts in 566 days
152 days ago
I have severe elbow tendonitis, along with other joint discomfort, from years of rock climbing. I have found deep tissue massage very helpful, painful at the time, but helpful overall. I also have good luck with a hot/cold soaking regamine. My sister, whom happens to have her phd in physical therapy, told me about this. Fill a bowl with ice and water and a bowl with water as hot as you can handle. Soak in the cold 15 min, then the hot 15 min. After a couple of rotations I my elbows feels much better. A shot of apple cider vinegar in the morning helps with overall joint pain, tastes like $#%@, but works. Avoid longterm use of anti-inflamatories. Good luck.
-- http://www.efcabineture.com/ You can be tired, or you can be broke, but you should never be tired and broke.
View SnowyRiver's profile (online now)
SnowyRiver
3489 posts in 379 days
152 days ago
I have had tennis elbow years ago. I was a very active tennis player…playing 6 days a week, 3 hours daily including tournaments etc. I switched to a different racquet and wholla, I got tennis elbow…never had been bothered by it before. I put up with it for some years. Some times it would hurt more than others. I also did home remodeling and deck building and it was starting to make work difficult. I finally went to my doctor and just told him I was fed up with it and to try cortisone. He did one injection and the moment he did the shot the pain was gone. I rested it for two weeks, then started to carefully play tennis again. It hasnt bother me since and I had played for years after with no problem. Although I am now retired from tennis, it doesnt bother me anymore. You might see if an injection would help, then be carefull for a few weeks until it heals.
-- Wayne - Plymouth MN
almostsquare
152 days ago
I did go and get an injection and it seems to be working. During the down time I have taken my lathe apart and am in the process of tuning it up as I reassemble. Just about ready to start turning again so I will see if the injection did indeed do the trick. I have also raised the height just a bit and am hoping that will help too.
-- Kelly in Canton
SnowyRiver
152 days ago
Sounds good Kelly. Good luck with it. I know its a pain… literally.
