Flip Top Cart Help
Forum topic by todd4390 posted 03-26-2015 08:47 PM 1025 views 0 times favorited 7 replies Add to Favorites Watch
View todd4390's profile
todd4390
136 posts in 1430 days
03-26-2015 08:47 PM
I’m building this flip cart and cut the two bottom shelf pieces to what I felt was the correct width to give me a straight and square assembly that would allow the flip top to be as tight to the sides as possible. In these pics I have the right side square with the top shelf but the left side is out between 1/16 to 1/8” as seen in the closeup of the square. If I rack the whole cart to the right to bring that into square then the right side goes out of square. Have I cut the shelves too narrow or too wide. I’m having trouble wrapping my head around this with the spinning top that I need to keep tight together to maintain full capture of the rod in the top. It seems like if I made the shelves wider it would kick the bottom out and bring it into square but I’m also worried it would push the sides out further from the top edges. Please help. By the way this is just a dry assembly at this point.
7 replies so far
View nkawtg's profile
nkawtg
272 posts in 1214 days
#1 posted 03-26-2015 09:44 PM
Could the pivot bar be spreading the left and right sides?
View MT_Stringer's profile
MT_Stringer
3160 posts in 3194 days
#2 posted 03-26-2015 09:48 PM
Can you rotate the pics. That would be helpful.
todd4390
#3 posted 03-26-2015 11:48 PM
Nope the pivot bar is just shy of bottoming out. I wish I knew why my photos get rotated when I post them. They are oriented correctly before I post them.
View copcarcollector's profile
copcarcollector
256 posts in 2080 days
#4 posted 03-27-2015 12:19 AM
pics
MT_Stringer
#5 posted 03-27-2015 01:36 AM
Can you add a washer (or shim) to one side or the other so the top will swivel?
todd4390
#6 posted 03-27-2015 10:17 AM
I already have two nylon washers between the top and the sides. The top spins fine but as you can see from the square the sides are further out at the top than at the bottom
View bondogaposis's profile
bondogaposis
4680 posts in 2314 days
#7 posted 03-27-2015 01:36 PM
It looks the bottom shelves are cut too short or the plywood is warped. Can you bring it into square if remove the swivel top?
-- Bondo Gaposis
