tool to make screw threads in wood?
Forum topic by DavidL41 posted 03-26-2015 05:07 PM 1287 views 1 time favorited 8 replies Add to Favorites Watch
View DavidL41's profile
DavidL41
11 posts in 1069 days
03-26-2015 05:07 PM
What is the name of the tool that makes screw threads in wood and to make the threads for the dowel?
Is there a manual version of this tools?
Can this same tool be used to make this in steel?
8 replies so far
View johnstoneb's profile
johnstoneb
2794 posts in 2082 days
#1 posted 03-26-2015 05:10 PM
Tap and die for wood. Yes they are manual, No they can’t beused in metal. depending on the wood species, sizw abd thread count metal taps and dies can make threads in wood. but not always successfully.
-- Bruce, Boise, ID
View RogerM's profile
RogerM
790 posts in 2308 days
#2 posted 03-26-2015 05:11 PM
David -These come in a lot of sizes: Check this one out:
http://www.highlandwoodworking.com/manualwoodthreader1-126tpi.aspx
-- Roger M, Aiken, SC
DavidL41
#3 posted 03-26-2015 10:14 PM
thanks a lot.
View waho6o9's profile
waho6o9
8100 posts in 2486 days
#4 posted 03-26-2015 10:34 PM
View rwe2156's profile
rwe2156
2804 posts in 1390 days
#5 posted 03-27-2015 11:01 AM
What thread size are we talking about here?
A regular tap (or even the screw itself) will work in hard wood, but for larger screws, you need one made for wood.
The Beall kits are pretty expensive, as I recall.
Woodcraft carries a 1 1/2” kit.
View bigblockyeti's profile
bigblockyeti
4994 posts in 1629 days
#6 posted 03-27-2015 11:43 AM
I’ve used 1” & 1 1/2” SAE coarse taps for wood before. Cutting threads in wood dowels on a metal lathe is messy and not that great for the lathe either.
TheWoodenOyster
1313 posts in 1844 days
#7 posted 03-27-2015 12:01 PM
By the by, you can use a regular hardened steel tap and die set for metal. In fact, most tap and die sets I’ve ever seen are made for metal. They make some for wood as well, but typically they are meant for metal. Something like the beall threader though… not made for metal, so don’t try it.
-- The Wood Is Your Oyster
View Jim Finn's profile
Jim Finn
2622 posts in 2831 days
#8 posted 03-27-2015 01:18 PM
I have drilled and tapped into oak to fit a machine screw and small enough works OK. (1/4”) I also have a 3/4” tap and die tool for wood. I have learned to only use this tool on hard wood like oak and soak it in linseed oil over night before trying to put threads on an oak dowel.
