Repeat dados, wider than dado stack, is this possible?
« back to Joinery forum
Forum topic by onesojourner posted 03-26-2015 03:14 AM 1131 views 0 times favorited 10 replies Add to Favorites Watch
View onesojourner's profile
onesojourner
73 posts in 1709 days
03-26-2015 03:14 AM
Hopefully this picture expains what I am trying to do. Each bar has 8 evenly spaced cuts. I have 20 of them to do. My dado will not cut the full width of the cut in one pass. I thought I had this figured out but when I went to do it I failed. I scratched my head for about 2 hours and made lots of test cuts but I could not come up with anything. I also have a router table I can utilize but only one miter guage.
-- http://icftfsystemshome.blogspot.com/
10 replies so far
View mark4345's profile
mark4345
71 posts in 2416 days
#1 posted 03-26-2015 03:42 AM
Make a box joint jig to index the cuts
View waho6o9's profile (online now)
waho6o9
8187 posts in 2570 days
#2 posted 03-26-2015 03:53 AM
https://www.youtube.com/watch?v=NutwD7B6tmE
William Ng ^
Good idea Mark4345
View TheFridge's profile
TheFridge
9435 posts in 1479 days
#3 posted 03-26-2015 03:55 AM
Yeah buddy
View realcowtown_eric's profile
realcowtown_eric
608 posts in 1930 days
#4 posted 03-26-2015 04:39 AM
Get some inexpensive plastic shimns and widen it so you can do it at one go,
Most dado heads have negative rake, so they tend to lift the work. with all the ones I use, two passess are required for precise depth.
Eric
-- Real_cowtown_eric
onesojourner
#5 posted 03-26-2015 12:38 PM
- mark4345
That was my thought to, and that is how I cut this scrap. The space between the end and the first cut is perfect, but the next cut will be wrong until the rest of the waste in the first cut is removed.
onesojourner
#6 posted 03-26-2015 12:48 PM
I think maybe instead of having the spacer 15/32nds from the closest edge of the blade, maybe I should have the spacer in my jig set at 45/32nds from the outside of the blade. that would get my first cut in the right spot then I could just put the opposite face up against the fence and it should come out perfect… right?
View Kazooman's profile
Kazooman
1005 posts in 1945 days
#7 posted 03-26-2015 12:58 PM
Yep, box joint jig. Set it up to cut all of the left hand sides first so they will have the proper spacing. Then reset it to cut out the remaining portion of the slots in a series of second passes.
View distrbd's profile
distrbd
2252 posts in 2439 days
#8 posted 03-26-2015 01:02 PM
Eric
- realcowtown_eric
Exactly.you need a couple of spacers to do accurate cuts.
-- Ken from Ontario, Canada
View MrRon's profile
MrRon
4757 posts in 3236 days
#9 posted 03-26-2015 06:57 PM
This is basically a large finger joint jig. Make your first 15/32 cut. Then index every 1-13/32 and repeat cut until all cuts have been made. Then go back to the start. Remove the last bit of the first cut and index the rest the same 1-13/32 until all have been done.
onesojourner
#10 posted 03-26-2015 07:27 PM
- MrRon
Awesome. That is what I was thinking. Thanks.
