Planer upgrade: Makita 2040 vs. Powermatic 209
Forum topic by RipFence posted 03-26-2015 01:09 AM 2205 views 0 times favorited 5 replies Add to Favorites Watch
View RipFence's profile
RipFence
77 posts in 2691 days
03-26-2015 01:09 AM
Hello All:
I’m writing for advice about some planer upgrade options.
I have a Makita 2040 which I am thinking about upgrading to a Byrd cutter head. I really like the Makita’s poly feed rollers that allow a very small finish cut with no marks like you might get from serrated rollers. I don’t love the noise of the 6500 rpm universal motor so much. I have thought about replacing the motor with a good induction motor which will be a bit of a project but nothing I can’t handle. The Byrd head will be about $1100. Changing out the motor might be two or three hundred by the time I’ve got the motor and pulley etc.
But…
There is a used Powermatic 209 for sale near me for a screaming good price and the guy will deliver. Byrd cutter heads for those are only $875. Its possible to turn down the feed rollers and have them poly coated so that I could still have my near zero cut option. My guess is that I could have the Powermatic with Byrd head and poly rollers for ~$2k. One thing I noticed when I looked at reviews on the Powermatic is that most reviews are highly positive but several people have posted fairly negative reviews.
Selling price on a Makita 2040 is a crap shoot but I wouldn’t count on getting more than $400-500.
Just in the process of writing this I may have convinced myself that the Powermatic option might be the way to go.
What would you guys advise?
Of course, I could just keep using my Makita as it sits which is a really nice but loud planer.
Jim
5 replies so far
4986 posts in 2491 days
#1 posted 03-26-2015 11:01 AM
I’m not familiar with the Makita, but the PM is a very good planer. Bear in mind, almost anytime you read reviews on anything, there will be some complaints. Hell, I have a Delta 15” which i really like and I still have some complaints about it. The PM is built along the lines of most of the planers, is easy to service (relatively) and a work horse. As I read through your points, I think I would go with the PM. One thing I can guarantee you is the you will be happy with the lower noise level (after the Shelix is installed). Before I installed mine, my planer was the only tool in the shop where I had to wear my shooting muffs while I was running it (this is with a DC hooked to it). The howl was awful. With the Shelix, I can use the same ear plugs I use with the other tools.
View MrUnix's profile
MrUnix
6710 posts in 2197 days
#2 posted 03-27-2015 05:53 AM
I’ve got the Makita 2030 (actually, two of them), which is the baby brother to your 2040 (with a jointer added), and love it even though it is a bit on the loud side. But not as loud as many of the lunchbox things out there! I’ve thought about retro-fitting an induction motor, but it seems like too much hassle and it’s so much easier (and cheaper) to just wear some ear muffs when using it. Never considered getting a helical head for it either as the finish that the machine produces is smoother than a babys butt, and I have never found any other machine that is easier to set knives on (that can be sharpened).
I agree with Fred that pretty much every machine will have some negative reviews… however I’ve never really seen any for the Makita 2030/2040 machines other than about the OEM feed rollers that deteriorate after about 30 years :)
In the end, it’s really up to you to decide if the extra ~5” and less noise is worth it to you. Everybody has different needs and circumstances. I’m not sure the helical head would buy you any better of a finish than what the Makita can produce (it’s considered a finish planer, which is why you can’t hog off huge cuts).
RipFence
#3 posted 03-27-2015 02:09 PM
Thanks Brad! I agree on all points. The noise isn’t that bad for me personally but lots here are 1/8 acre and I feel like its pretty loud to my neighbors with small children. I don’t want to be That Guy in the neighborhood. I also love how easy it is to change blades and agree that the finish is really good. I have the slow speed gear option on mine so the finish is even better than standard. But, I work mostly with quarter sawn white oak. Often times the most spectacular figure gets torn out due to grain direction changes. I have a Byrd head on my jointer and it gives me a great surface with no tear out. My 2040 came with non-original feedrollers that have not deteriorated at all.
So, as it stands now I have a really really good set up. I just want to see if I can improve it a bit on noise and tear out. The additional 5” isn’t really that attractive to me but might come in handy with a glue up now and again.
I went ahead and committed to the Powermatic 209. The deal was so good ($950 delivered) that if I don’t like it I should be able to sell it and not lose much if anything.
Jim
MrUnix
#4 posted 03-27-2015 02:30 PM
You are lucky… I’ve been searching for the low speed gear set for years. They are a rare beast.
RipFence
#5 posted 03-27-2015 02:34 PM
I didn’t know those were rare. When I got my planer in about 04 I simply googled and ordered it. Sorry but I don’t know where I bought it.
Jim
