sanding sealer getting too thick
Forum topic by SCOTSMAN posted 06-24-2009 08:30 PM 1320 views 0 times favorited 8 replies Add to Favorites Watch
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3586 days
06-24-2009 08:30 PM
I don’t know if it’s the weather or what but I have a large plastic container of sanding sealer which has become very thick. It now resembles custard and I have been told that you can add thinners to it to make it more easy flowing any ideas Alistair
8 replies so far
3809 posts in 4022 days
#1 posted 06-24-2009 08:33 PM
See if it’s lacquer based sealer and if so you can get some lacquer thinner at a paint shop.
If it’s water borne just use tap water.
SCOTSMAN
#2 posted 06-24-2009 08:38 PM
Hi Bob it smells like it’s got thinners I will try alittle bit with water but I am sure it’s going to be thinners I need . I didn’t know if I could add this, or not. It’s a big container and I don’t want to chuck it out or ruin it thanks Bob Alistair
View YorkshireStewart's profile
YorkshireStewart
1130 posts in 3902 days
#3 posted 06-24-2009 09:02 PM
It could be shellac based which I believe is dissolved in alcohol / methylated spirit, but it sounds like you’ve already identified it as cellulose. Should be no problem in diluting with cellulose thinners.
-- Res severa verum gaudium - True pleasure is a serious business. http://www.folksy.com/shops/TreeGems
SCOTSMAN
#4 posted 06-24-2009 09:09 PM
Stewart you’ve thrown me a wobbly my brother! It might indeed as you say be shellac It smells very sweet I automatically though it must be thinners but you could be correct.How do I tell ? Alistair
#5 posted 06-24-2009 09:42 PM
Where’s the label Al?
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3287 days
#6 posted 06-24-2009 10:53 PM
If it is in a plastic container, I seriously doubt that it’s lacquer. Lacquer will usually melt plastic. You may just have to experiment with different solvents to figure it out (on small samples of course)
Good luck Alistair
-- http://shepherdtoolandsupply.com/
SCOTSMAN
#7 posted 06-24-2009 10:58 PM
I transferred it into this container a few years ago it was in another similar container I have had it for a while hence no labels etc.Alistair
27250 posts in 3822 days
#8 posted 06-25-2009 12:29 AM
Alistair, it really does not matter which one you use. Lacquer thinner and denatured alcohol will combine. So you can use either one to thin your shellac. Given the plastic container, if it were me, I would use denatured alcohol.
