One Cut, Two Results: One side smooth, the other torn out?
Forum topic by thiel posted 155 days ago 467 views 0 times favorited 15 replies Add to Favorites Watch
View thiel's profile
thiel
95 posts in 188 days
155 days ago
Topic tags/keywords: cut problems tablesaw tool setup tuning
Gang,
Any ideas for what’s causing this problem? The attached photo shows two sides of the same cut, and as you can clearly see one side is crisp and the other ragged. Thoughts?
Other details:
—Grizzly 3hp saw
—Forrest Woodworker II blade
—No splitter or guard
—I also get a lot of sawdust blowing back at my face while I cut. This is particularly prominent with plywood.
I had wondered if this meant my saw was out of tune in a particular way…. any ideas of where to look
first? (I recently moved and thought I’d successfully dialed in all my equipment, but then this started to happen).
Cut Detail
-- Laziness - Apathy = Efficiency
16926 posts in 473 days
155 days ago
Well David
It’s hard to believe it’s the same cut , the right side looks as if it didn’t quit cut all the way through with no evidence of the left having torn off from the left. It’s not a dull blade because you would have burn and its not a dirty blade for the same reason. I would say to try anther blade and see what it looks like. Perhaps it’s a bad or damaged blade or sharping job.
View PurpLev's profile
PurpLev
2759 posts in 545 days
155 days ago
looks like most likely one side of the blade has some dulled out teeth that are tearing one side of the cut. another though – since you mentioned you do not use a splitter – might it be that the side that is not running against the fence is pinching the blade on the back side as it passes it, causing the blade to shred it’s surface?
which side of the blade is the CLEAN side? the one running against the fence? or the cutoff side?
thiel
155 days ago
I believe the clean side is between the blade and the fence. Not entirely certain about that though, but probably 85% confident.
I have a thin kerf freud blade I can try tomorrow, but it’s got 90+ teeth, so I’m not sure it’s a good comparison for diagnosis.
I was hoping one of you would say “oh yeah… your whozitz is out of alignment with your whatzis… happens all the time…”!
View Myron Wooley's profile
Myron Wooley
220 posts in 792 days
155 days ago
This is an alignment issue. You need to verify that the blade and fence are both precisely aligned with the miter slot. The best way is to use a dial indicator mounted in a jig, either the TSAligner or the the A-Line-It. The straighter you can get everything, the better. I have my fence about .004” open to the blade at the back. Any more, and the teeth on the backside of the blade will frizz the offcut and throw sawdust in your face like you are seeing. Too much, and you are setting yourself up for a kickback.
If the fence is closed at the back, i.e. the gap narrows as you go, the workpiece will bind on the blade. Another dangerous situation.
-- The days are long and the years are short...
View bentlyj's profile (online now)
bentlyj
789 posts in 366 days
155 days ago
thiel…...your whozitz is out of alignment with your whatzis. :)
I agree with Myron, also check your blade to see if you have any chipped teeth.
thiel
154 days ago
Thanks. I’ll hunt down the alignment issues tonight and let you know!
thiel
149 days ago
Turns out everything was in tune. The problem? The blade is warped! I checked against a flat reference surface because my dial indicator was giving me CRAZY readings.
Another blade on there and alls well. Now it’s time to send the first one back to Forrest!
View davidroberts's profile
davidroberts
242 posts in 382 days
149 days ago
forrest should be able to beat it back to flat. i have the same setup, WWII blade and Griz 3hp. now i’ll know what to look for, if i see it :)
-- david roberts, houston area, "A little knowledge is a dangerous thing, but that has never been a problem for me."
PurpLev
149 days ago
interesting outcome – thanks for posting, another thing to consider in the future :)
thiel
149 days ago
... now, of course, “everything was in tune” to a warped blade :-) So… now I’ll retune (again) with a flat one.
BTW… instead of an Aligner jig, I use a magnetic dialcaliper stand stuck right to the face of my mitre gauge. Works great :-)
View Don Newton's profile
Don Newton
532 posts in 515 days
149 days ago
Warped blade…..who’d have thunk it!
-- Don, Pittsburgh
View jerryz's profile
jerryz
109 posts in 175 days
149 days ago
Well Well, that is indeed an interesting find, good to know if ever I come across something like that.
thiel
114 days ago
FYI… I sent the blade back to Forrest and they replaced it no problem. I can vouch for their customer service level… they could not have been more reasonable and responsive. Class act there.
As far as I can tell, the blade has been warped for a LONG time. My saw is now running like butter.
View Innovator's profile
Innovator
3125 posts in 310 days
114 days ago
I am glad to hear they got it done for you, the problem is the pulling out your hair exercise you have to go through to find the problem.
Good Luck with the new one.
-- Whether You Think You Can or You Think You Can't, YOU ARE RIGHT!!!
View mics_54's profile
mics_54
441 posts in 367 days
113 days ago
oh…nevermind
-- Dan, Sterling Alaska, http://sullcon.homestead.com/ Before you criticise some one, walk a mile in their shoes...then you will be a mile away and you have their shoes!
