Fitting Box Joints
Forum topic by swied posted 159 days ago 467 views 1 time favorited 10 replies Add to Favorites Watch
View swied's profile
swied
54 posts in 661 days
159 days ago
Topic tags/keywords: box joint finger joint jig router
I have a question about using the box joint router jig that I recently bought (see below). It is a great little jig, and is easy to use. The only problem is that I always have to file down my cuts by hand afterwords. Otherwise, the fit is too tight. I have a project in mind that is going to require a lot of these box joints, and I am not looking forward to filing them all down. The directions aren’t much help. Does anyone have any ideas on how to get the fit dialed-in, or do you always have to follow-up with a file?
jig!http://images.rockler.com/rockler/images/29502-09-500.jpg(jig)!:http://www.rockler.com/product.cfm?page=21338&filter=box%20joint%20jig
-- Scott, San Diego
17141 posts in 476 days
159 days ago
How about a larger router bit.
swied
159 days ago
Here is an example of some box joints from my last project. I had to do a lot of filing to get it all to fit together.
“>http://widgets.lumberjocks.com/project/15786.jpg
-- Scott, San Diego
swied
159 days ago
A larger router bit? I don’t understand. If I am making 1/2 inch fingers, then don’t I need a 1/2 inch bit?
-- Scott, San Diego
2465 posts in 240 days
159 days ago
is your bit new ?
if it has been sharpened it might be a hair smaller than 1/2 ”
or the registry rail might be a hair over size .
caliper them both , and either get new bit or size indexer .
i.e. sand it down carefully or pad it out with some pacaging clear tape .
i hope this helps.
View Chiefk's profile
Chiefk
97 posts in 670 days
159 days ago
Sweid, I suggest you give Rockler’s Technical Shop a call and describe to them the problem. It most likely is a minor problem, they can help to correct. pkennedy
-- P Kennedy Crossville, TN
View coloradoclimber's profile
coloradoclimber
447 posts in 967 days
159 days ago
Swied,
Let me see if I can explain this without pictures. The problem is really pretty simple and the adjustment for your jig is simple too. I have a jig similar to this and here is your problem:
The gap between the index key (the metal bar that you index off) to the router bit is not EXACTLY the same as the diameter of the router bit. If your finger joints are tight or loose that IS your problem.
Think about it, the finger size (width) is set by the gap between the bar and the bit, the cut out space between the fingers is the diameter of the router bit. If the fingers are not exactly the same size as the router bit they wont fit right.
The router bit you’re stuck with, whatever size it came from the factory is the size it is. So you have to adjust your gap to be the same as the router bit. If your joints are too tight that means your fingers are bigger than your cuts between the fingers so you need to move the index bar closer to the bit to shrink the fingers.
If you have a set of calipers measure the bit diameter and the finger size and I bet you will find a difference.
The rockler manual for the jig is saying the same thing, maybe not as clear, or maybe more clear, but here’s the paragraph from the manual saying the same thing I just tried to say above. Note specifically the word equal, when they say equal it doesn’t mean almost equal, it means as close to equal as you can reasonably get.
5. Adjust the gap between the bit and the indexing key to equal the diameter of the bit. 1/4” box joints, for example, would require a 1/4” router bit, a 1/4” indexing key, and a 1/4” gap between the two. To adjust the gap, move the jig side-to-side in the miter track. Then lock it in place with the 5-star knobs. Note: Use a test piece to be sure your settings are correct and your joints fit tightly.
I find some trial and error works best, cut some test fingers on a couple pieces of scrap, test the fit, tweak the spacing, test again, perfect fit.
And the part in the manual where they suggest using a brass setup block to set the spacing, don’t count on it. The brass bar will get you close but I have yet to find a router bit that was EXACTLY the diameter it says it is. Even a thousandths or so off adds up to stuck fingers after you get ten or more fingers in a joint.
Use the brass bar to start off but expect to do some test cuts and tweak it.
All of these finger joint jigs are pretty much the same and pretty simple, the table saw or router types. A gap and a cutter. The spacing between the indexing pin / bar / rail / whatever to the cutter needs to be the same as the cutter width (diameter). Whether the cutter is a router bit or a dado stack. The cutter you are stuck with, whatever size it is it is, so you tweak the spacing to match the cutter.
View brad's profile
brad
135 posts in 803 days
159 days ago
I don’t have the Rockler jig, but the principle is the same with any finger joint….coloradoclimber is right ion.
-- Brad,--"The way to eat an eliphant is one bite at a time"
159 days ago
i never used one of these jigs ,
so didn’t notice the side adjustment .
i’m sure it is as colorado says ,
got to get me one !
enjoy the rest of the work ,
and show us the results .
and a big smile for not having to file for the rest of your life !
View Divotdog's profile
Divotdog
36 posts in 342 days
159 days ago
I agree with Brad and Coloradoclimber. I am no expert put I have logged some hours pushing my box joint jig.
The size of the bit doesn’t matter (as long as it doen’t change) but the size of the spacer, gap, index key or whatever you call it really needs to match the cut size. If your first cut (on the edge) exactly matches with the size of the spacer, then you have have it made – just hold on tight and be safe!
Also, the height of your spacer really does not matter as long as it is no higher than your bit height.
-- David, Dallas,Tx - golfing weather is nice but so is woodworking!
swied
159 days ago
Sounds like good advice. I’ll give it try. Thanks!
-- Scott, San Diego
