1938 sears craftsman lathe info needed..................
Forum topic by bob koller posted 08-27-2007 01:39 AM 2589 views 0 times favorited 12 replies Add to Favorites Watch
View bob koller's profile
bob koller
11 posts in 4162 days
08-27-2007 01:39 AM
i had a friend give me this lathe for the shipping cost to him to ship it to me….
the pulley for the headstock shaft broke in shipping….
i tried a search on the web for pulleys but nothing i could use came up….any info that anyone can give me to sources where i can get a pulley would be great….thanks….............bob
12 replies so far
View brunob's profile
brunob
2277 posts in 4403 days
#1 posted 08-27-2007 02:09 AM
Try: “http://www1.mscdirect.com/CGI/GSDRVSM?PACACHE=000000026472224”
Most industrial supply houses either have them in stock or can gwt them for you.
-- Bruce from Central New York...now, if you'll pardon me, I have some sawdust to make.
35152 posts in 4634 days
#2 posted 08-27-2007 02:15 AM
Yes you should need the shaft diam and the step pulley sizes.
-- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Appomattox Virginia karsonwm@gmail.com †
bob koller
#3 posted 08-27-2007 02:35 AM
duh, sorry….shaft mic’ed at .749” and the pulleys i.s dia is 3/4”....................bob
View WayneC's profile
WayneC
13794 posts in 4331 days
#4 posted 08-27-2007 03:20 AM
There might be info on the lathe on http://owwm.com as well.
bob koller
#5 posted 08-27-2007 06:40 AM
i have that site saved, thanks….............bob
bob koller
#6 posted 08-27-2007 04:35 PM
found a pulley on McMaster Carr’s website for 16.00 bucks, but it is a little differnt then my pulleys specs….
.......................OD. steps…...........................pitch dia.
.............1…......2…......3….......4….. ..........1…...2….....3…...4
..........1 3/4”...2 1/4”...2 3/4”...3 1/4”.........1 1/2”...2”...2 1/2”...3”
...........(X) height 2 5/16”
mine are….
............1….......2…......3…...4…...... .......1…....2…......3…....4
.........1 3/4”...2 1/2”...3 1/4”...4”...............1”...1 1/2”...2 1/4”...3”
...........(X) height 2 3/4”
how far off will the RPM’s be, or it won’t matter much or at all with a
1/2 HP 1725 RPM motor….............bob
View olddutchman's profile
olddutchman
187 posts in 4169 days
#7 posted 08-27-2007 10:55 PM
It should not make s lot of difference for you. Now ,if You were used to using the tool on a regular basis, then You would see a difference on Your speeds. Since You have not used it as of yet., You should be just fine
-- Saved, and so grateful, consider who Created it ALL!!!
Dick, & Barb Cain
8693 posts in 4533 days
#8 posted 08-28-2007 02:11 PM
It looks like a close enough match. If you have a bearing supply store in your area, bring your pulley to them, & they should be able to match you up.
bob koller
#9 posted 08-29-2007 07:46 PM
here’s an update on how i’m going with it so far….got it cleaned up a bit and the shaft back in the headstock frame….
before….
after….
here’s the whole lathe….
so far i just need 2 pulleys and a motor….when done it looks like i’ll have a good work horse of a lathe for bout 175.00 bucks….....................bob
WayneC
#10 posted 08-29-2007 08:23 PM
Looks like your making good progress. Any consideration to replacing the bearings?
bob koller
#11 posted 08-30-2007 12:32 AM
i cleaned the bushings up with some plumbers sanding cloth, the screen type that you sand pipe with before ya soldier them up….i taped the end of a piece to a 3/8” dowel and with my drill i wound it up till it just barely fit the 3/4” bore….i more or less honed it out till smooth and was able to get the shaft back in the headstock….with the shaft in place there’s no slop up and down and it spins smoothly right now….what kind of oil would be best in them oil cups on top, and does the bushings just soak up what ever oil goes in there to lube the shaft….......................bob
View Dadoo's profile
Dadoo
1789 posts in 4224 days
#12 posted 08-30-2007 02:50 PM
Here are two links to part suppliers I have used. Hope you can find what you need.
www.acetoolrepair.com and www.toolpartsdirect.com .
