Air Conditioning Sizing?
Forum topic by spanky46 posted 06-21-2009 04:36 PM 3870 views 0 times favorited 7 replies Add to Favorites Watch
View spanky46's profile
spanky46
995 posts in 3354 days
06-21-2009 04:36 PM
Topic tags/keywords: question air conditioning sizing cooling
My former garage and now workshop is 24’ by 24’ by an average height of 9.5 ’. Taking out for cabinets and equipment (see workshop my site) I need to know the approximate size wall mounted AC required. The shop is insulated and has one 16’by 7’ garage door, one 3.0 outside door and 2- 48” by 48” insulated windows.
It has a sloped concrete floor.
Any information would be greatly appreciated! Trying to find something used!
-- spanky46 -- Never enough clamps...Never enough tools...Never enough time.
7 replies so far
Craftsman on the lake
2781 posts in 3402 days
#1 posted 06-21-2009 04:42 PM
Hmm…. I’d say anything about or over 10,000 btu would be more than enough. An 8000 would work well too but probably run longer. I doubt that 6000 which is like a bedroom ac unit would keep up. It all depends on your outside temp. If you’re in the south then bigger. If in the north just dealing with the summer then smaller.
And I’m no AC expert. It’s just that I have a 24×24 insulated shop too. Mine is 16000 btu. It’s way overkill but it was given to me as a used unit. I never would have sprung for one that size if I had bought it new. I don’t have a garage door though so can’t speak for how that would be.
View Maynard's profile
Maynard
36 posts in 3268 days
#2 posted 06-21-2009 04:45 PM
Take the square footage of your shop to a local appliance store and determine from them the size of your unit that is suitable for your climate.
Then you can buy one used that is that size.
Larry
View cabinetmaster's profile
cabinetmaster
10874 posts in 3522 days
#3 posted 06-21-2009 04:47 PM
Where are you mounting this unit? I’d go look at Lowes or Home Depot. They usually go by the size of the room. Yours is 24×24 or 576 square feet. I’d see what they reommend in BTU’s for that size room and get the next size bigger. I bought one and mounted it in my window. It was rated for the size of the room and justs gets by. I wish I had bought the next size bigger.
spanky46
#4 posted 06-21-2009 04:56 PM
Cabinetmaster, I will be mounting it in a wall with a southern exposure but there is a 3 foot overhang and lots of shade!
View BTKS's profile
BTKS
1986 posts in 3428 days
#5 posted 06-21-2009 08:02 PM
Spanky,
Go with recommended size for climate or ONLY ONE size bigger. Too big and it will not run long enough to dehumidify. Most of the advantage to AC is the drop in humidity and comfort factor, not necessarily to temp.
Bigger is not always better. Been through that scenario with a small house. 24,000 BTU too big, 18,000 just right. Good luck
BTKS
-- "Man's ingenuity has outrun his intelligence" (Joseph Wood Krutch)
16274 posts in 4182 days
#6 posted 06-21-2009 11:57 PM
BTKS is right. The last thing you want is a unit that is too big for the space. As he said, it will short-cycle, leaving too much humidity in the room. Not only is this a comfort issue, but you could easily wind up with condensation on your metal tools and surfaces… not a good thing.
View MedicKen's profile
MedicKen
1612 posts in 3426 days
#7 posted 06-22-2009 12:57 AM
I have a standard 2 car garage that has been insulated in all walls and the ceiling. R19 in the walls and R30 in the ceiling. I have a 10,000btu window unit that I installed in the mandoor, cut a hole and made a support shelf/bracket. It does a fairly decent job of keeping it tolerable. In my climate, avg summer temp of about 95, with an easterly exposure to an insulated metal garage door, inside temps range in the low 80’s.
