New (to me) planer - RBI 612
Forum topic by WillliamMSP posted 03-23-2015 02:41 PM 6335 views 0 times favorited 16 replies Add to Favorites Watch
View WillliamMSP's profile
WillliamMSP
1084 posts in 1601 days
03-23-2015 02:41 PM
Whelp, I done did it. After nearly losing my patience (and sanity) with combing the backwaters of Craigslist, all while debating “lunchbox or stationary?” I came across a promising ad for a planer a just over 100 miles away. Seemed to do just dandy on the test board that was run through it and all the parts that are supposed to move do so freely and smoothly – no rattles or bumps. The arrow for the thickness indicator needs to be replaced and I’ll have to find/make a knife setting jig eventually, but everything under the hood (3hp motor, belts, pulleys, rollers, etc) seems pretty solid. Price was $250 and a half a tank of gas for the round trip.
(in/outfeed tables were taken off for transport)
My understanding is that this is the same, or very similar to, the Woodmaster 612; I’ll have to find a manual and go through it and then make any adjustments necessary – any advice to a n00b is welcome. In any event, I’m glad to be done looking and happy to have a major piece of my budding shop in place.
-- Practice makes less sucky. (Bill, Minneapolis, MN)
16 replies so far
View HornedWoodwork's profile
HornedWoodwork
222 posts in 1211 days
#1 posted 03-23-2015 05:04 PM
HOT DAMN! What a find, that’s a beauty. I have no advice for you at all just wanted to drool a little with you. Once you get it tuned up I’m sure it’ll true your stock up nicely.
-- Talent, brilliance, and humility are my virtues.
View moke's profile
moke
1175 posts in 2773 days
#2 posted 03-23-2015 05:14 PM
no advice, but let me be the first to tell you….you suck!!!! Seriously your patience paid off…good job..
Mike
-- Mike
View ChefHDAN's profile
ChefHDAN
1062 posts in 2846 days
#3 posted 03-23-2015 05:37 PM
Wow SCORE! You SUCK!
View waho6o9's profile (online now)
waho6o9
8190 posts in 2574 days
#4 posted 03-23-2015 05:43 PM
http://www.hawkwoodworkingtools.com/files/Planer/model_612_Planer.pdf
Congrats William!
Bushton
Manufacturing
Hawk
Woodworking
Tools
MODEL
612
PLANER
OPERATORS
MANUAL
FOR
(JOINTER)
(SANDER)
(PLANER)
(MOLDER
WillliamMSP
#5 posted 03-23-2015 06:26 PM
^^^ Cool – thanks for that!
Ha – I thought that it was a decent deal (a local shop that sells used machinery has one of these, with no knives, at $600), but I wasn’t sure if I was in ‘you suck’ territory or not.
View gfadvm's profile
gfadvm
14940 posts in 2687 days
#6 posted 03-24-2015 01:40 AM
I think you did very well! The knife setting gauge from Woodmaster works well and should work on your machine (and was the cheapest option when I shopped around).
View Dan Krager's profile
Dan Krager
4001 posts in 2231 days
#7 posted 07-26-2015 07:44 PM
Hawk should have pretty good customer service. If not I can answer most questions about the machine since I’ve had one since they came out under RBI, and for whom I sold the machines. It has seen lots of trouble free mileage.
Take good care of the feed rollers and keep the bed waxed with a good quality slippery wax. Crank the bed all the way down and be careful of the knives. Clean the rollers with mineral spirits, kerosene, and I’ve used isopropyl alcohol. Their knife setting gauge is a must. I wish there was an easier way to reliably set the knives because it gets tedious when they move about as you tighten the gib. I’ve considered ways to temporarily secure the knives in place while the gibs are tightened, but nothing I’ve tried works reliably yet.
DanK
-- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com One should always prefer the probable impossible to the improbable possible.
View rwe2156's profile
rwe2156
2925 posts in 1478 days
#8 posted 07-26-2015 11:42 PM
Looks like a good deal.
Hey I’m looking at a Wixey digital plane gauge.
Check it out to replace the old indicator.
View fluidframe's profile
fluidframe
4 posts in 414 days
#9 posted 04-04-2017 06:40 PM
Thanks for starting this thread! I have the same unit and really want to start using the sander part of it. I bought some wrap around, 1 inch, non adhesive backed. Wrapped it and taped up the ends. Will hold for 9 or 10 boards as long as the boards don’t get under the tape. Wanting a better method though!
How have you RBI owners found as the best way to use the sanding part?
-- Josh FB @jfluidframe
Dan Krager
#10 posted 04-04-2017 11:20 PM
The abrasive strip needs to be secured its whole length for best longevity. This means using self adhesive stuff or spraying with an adhesive like 3M 77. A heavy backing is best. Removal is done with heat (hot air gun) or solvent but not both! Kliingspor has some great stuff!
It must be set to take very very light cuts and 100 grit is about the highest that can be successfully used and 60 is about the lowest, so it has a limited range. I think the faster feed speed doesn’t work as well as the slower feed.
I’ve tried a 36 grit wrap for abrasive planing, but between the heat generated by the sanding and the force required to drive the heavy grit through the wood, it wasn’t very successful.
DanK
fluidframe
4 posts in 414 days
#11 posted 04-05-2017 03:13 AM
Thanks Dan!
Wasn’t aware it had a slower feed rate :)
Will have to check that out! Thanks for the adhesive removal tip! Had concern to try something like that
Would love a link to your favorite paper for it! I’ve tried a few and they seem all over the place. But it could have been my taping!
Dan Krager
#12 posted 04-05-2017 01:27 PM
Sure. To be honest, I haven’t used the drum sander in recent years since I obtained the large thickness sanders.
Check out the aluminum zirconia Klingspor stuff. I bought some of those 80 grit belts for my Rigid oscillating sander and I think 5 belts is going to be a life time supply, even dedicating a couple to metal working.
DanK
fluidframe
4 posts in 414 days
#13 posted 04-05-2017 01:31 PM
Thanks Dan!
View jmartel's profile (online now)
jmartel
7887 posts in 2147 days
#14 posted 04-05-2017 02:13 PM
Bill, definitely put a Wixey gauge on it. Helps out tremendously.
View bonesbr549's profile
bonesbr549
1547 posts in 3064 days
#15 posted 04-05-2017 03:54 PM
Not familiar with that brand, but looks good and can’t beat the price for sure!
