cut a 27 degree angle on a 2x4"
Forum topic by daddywoofdawg posted 03-23-2015 12:33 PM 4934 views 0 times favorited 11 replies Add to Favorites Watch
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1482 days
03-23-2015 12:33 PM
Topic tags/keywords: milling
I need To cut a 27 degree angle on a 2×4”, it would need to be at 63 degrees.Most saws do not go that far.So how do I do that on a miter saw?or can it be done?
11 replies so far
View MrUnix's profile
MrUnix
6362 posts in 2106 days
#1 posted 03-23-2015 12:37 PM
Huh? You need to be a bit more specific… why can’t you cut a 27 degree angle?
daddywoofdawg
#2 posted 03-23-2015 12:48 PM
I need to have a 27 degree angle so wouldn’t I have to cut it at 63 degrees,90-63=27? or is it to early and 27 degrees on the miter saw will yield a 27 degree angle.
MrUnix
#3 posted 03-23-2015 12:48 PM
LOL – I’m pretty sure that a 27 degree angle on the saw will get you a 27 degree angle on the wood :)
Go have some coffee!
daddywoofdawg
#4 posted 03-23-2015 12:54 PM
will do
thanks, now that it’s typed out I don’t know why it didn’t register.
View Yonak's profile
Yonak
986 posts in 1428 days
#5 posted 03-23-2015 01:49 PM
From what reference is the 27° ? ..From the board edge, end or face ? If it’s from the end you should be able to easily cut across the board as Brad suggests. If it’s from the board edge or face I can understand how it would be more difficult.
What tool do you have to cut with ? ..Table saw ? ..Mitre saw ? ..Sabre saw ? ..Hand saw ?
Can you describe or make a sketch of the cut you want to make ?
View levan's profile
levan
472 posts in 2887 days
#6 posted 03-23-2015 02:02 PM
Yonak beat me to it.
-- "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
daddywoofdawg
#7 posted 03-23-2015 03:50 PM
power miter saw,and the drawing levan shows is the cut I need.have to recheck if it’s off side or end. off the top of my head it’s off end.
Yonak
#8 posted 03-23-2015 04:14 PM
If it’s off the end you should be able to set your mitre saw to 27° and be good to go. If it’s off the side it’s a bit more cumbersome but still pretty easy. I usually cut a temporary fence that’s 45°, clamp it against the mitre saw fence, set the piece to be cut against the 45 and set the saw to 18°. Re-check my numbers, but I think that will do it. You’ve got to confirm that your saw can make a long enough cut to cover the distance.
View hotbyte's profile
hotbyte
991 posts in 2883 days
#9 posted 03-23-2015 06:26 PM
Maybe an acute angle jig Not my project below but I did something similar to trim tops of pickets for a fence…
http://lumberjocks.com/projects/90167
EDIT – Exactly what Yonak described :)
View Ghidrah's profile
Ghidrah
667 posts in 1130 days
#10 posted 03-24-2015 10:36 PM
I believe it’s called the complimentary angle. The red block shows 27° it connects parallel sides, the green block shows 63 and 27° because it connects a 90° right angle which must equal 180°.
-- I meant to do that!
View jerryminer's profile
jerryminer
890 posts in 1349 days
#11 posted 03-25-2015 06:08 AM
For the miter saw, make an acute angle jig, as suggested by hotbyte above.
Can also be cut on the table saw with a sled (use hold-downs):
