My New Radial Arm Router
Forum topic by TTF posted 03-23-2015 03:42 AM 28984 views 6 times favorited 34 replies Add to Favorites Watch
View TTF's profile
TTF
154 posts in 3207 days
03-23-2015 03:42 AM
Topic tags/keywords: radial arm saw router shop-made tools
My project website: TF Workshop
I recently bought a 1950’s Dewalt radial arm saw, with the saw mount damaged (it was way cheap). I decided to mount a 1/2 router to the carriage – the set-up is shown below. I figure once I get a fence on it, I’m going to basically have a manual wood milling machine.
I know I’ll use it for quick material removal. I think it might end up being really useful. I already had the router, so for under $50, I have an experiment going.
-- Troy | http://tf-workshop.com | The more I see nature, the more I am amazed at the Creator. - Louis Pasteur
34 replies so far
View waho6o9's profile
waho6o9
8212 posts in 2606 days
#1 posted 03-23-2015 03:56 AM
I like it.
View joey502's profile
joey502
537 posts in 1547 days
#2 posted 03-23-2015 04:09 AM
Me too.
View pjones46's profile
pjones46
1001 posts in 2672 days
#3 posted 03-23-2015 04:51 AM
Great repurpose. Very innovative.
-- Respectfully, Paul
View dawsonbob's profile
dawsonbob
2889 posts in 1785 days
#4 posted 03-23-2015 02:50 PM
Not bad. Not bad at all. Pretty darn nice, in fact.
-- Mistakes are what pave the road to perfection
View MinnesotaMarty's profile
MinnesotaMarty
126 posts in 1247 days
#5 posted 03-23-2015 03:02 PM
TTF,
You beat me to the punch. I came across a Radial Arm Saw very inexpensive and in really good shape. So, I bought it and had the same idea. I have a Rockwell router that I rarely use and thought that the two combined might give me some additional options.
Looks like you fabricated the “router holder”.
I just moved and am in the process of resetting up my shop so the overhead wood milling machine might have to be delayed a bit.
Keep us posted of your progress.
-- I can see the cheese heads from here and it is great.
waho6o9
#6 posted 03-23-2015 04:26 PM
Maybe insert a pin in the T slot and make an overhead pin router?
View TTF's profile
TTF
#7 posted 03-23-2015 04:41 PM
Marty,
Yup – I fabricated the router holder out of white oak, so it would be solid.
Here is a picture from the bottom. Half circle cradle with hose clamps. On the right side of the cradle, I put in a metal tab to lock in the router so it wouldn’t spin.
Here is the back. I cut a hole to access the speed control, and it allows some additional airflow.
Good luck with your shop set-up.
View TTF's profile
TTF
#8 posted 03-23-2015 04:42 PM
I will try the pin router idea.
View TTF's profile
TTF
#9 posted 09-06-2015 03:22 AM
Update: I’ve been using this thing for about 6 months, and I really like it. I use it to cut slots and mortises all the time. I have also ended up using it for regular router functions, like edge rounding. Unlike my router table, I can see the bit and do slight adjustments easily.
I ended up buying another radial arm saw – a larger 1950’s DeWalt – as well for $30. I keep a 1/2” dado on it for removing lots of material fast. Between these two tools, my woodworking has gotten a lot more efficient.
View Woodknack's profile
Woodknack
11831 posts in 2409 days
#10 posted 09-06-2015 04:56 AM
Sweet. Wish I had room for one.
View BurlyBob's profile
BurlyBob
5558 posts in 2295 days
#11 posted 09-06-2015 05:08 AM
Ya just gotta love creative ingenuity. TTF your awesome!
View TTF's profile
TTF
#12 posted 09-06-2015 05:17 AM
Rick & Bob – thanks.
View oldnovice's profile
oldnovice
6904 posts in 3397 days
#13 posted 09-06-2015 06:09 AM
Always wanted to build an over arm router but never got around to it!
This is a superior machine you have there now, really nice work.
View TTF's profile
TTF
#14 posted 09-07-2015 03:11 AM
Oldnovice, thanks very much for your kind words and encouragement.
oldnovice
#15 posted 09-07-2015 04:04 AM
TTF, you know that many of the manual production routers use the over arm routers!
Multipe templates, many routers, much production without a CNC.
A shop, I once visited in Wisconsin, has a number of these along with a number of very large 4 spindle routers.
showing 1 through 15 of 34 replies
