| Forum topic by thelt | posted 160 days ago | 957 views | 0 times favorited | 14 replies | ![]() |
160 days ago |
I moved this from another forum that was probably not the right place to post it (since I dind’nt get any replies). Not to knock custom cabinets, but I am at a dilemma with the custom cabinets in my kitchen. I want to put in pull outs but the cabinet builder built them as face frames and the inside dimensions are 4 inches wider than the opening of the face frame. Also the sides of the cabinest are either luan or 1/4” plywood (hard to mount rails to). I’m not sure what to do other than rebuild the cabinet and hope I can use the drawer front and cabinet door. These are 25 years old and are going to be hard to match up the stain etc… Any Ideas from the experts? -- There are three signs of old age. The first is loss of memory. I forgot the other two! |
160 days ago |
thelt, I by know means am an expert, but seems your biggest problem is with the sides only being 1/4” if thicker I would suggest just adding stripes to bring it out flush with your face frame.I have done this before. With the sides being 1/4” seems to me you would have to make and entire panel to add to your sides, by the time you do that seems it would be easier to just make new boxes. I am sure you will get more and better advice. -- F.Little |
160 days ago |
If the sides are indeed 1/4” material… How about wooden rails to mount the slides flush with the inner edge of the face frame, mounted to several 3 or 4” wide x 3/4” thick vertical wooden rails? You could screw and epoxy the vertical rails to the sides, front, and back. The vertical rails would run from top to bottom, one each against the inside front and back, and intermediates as needed. Once they’re solid, mount your wooden mounts and metal slides. Good quality metal slides have a decent amount of rigidity themselves, I’m sure the assembly would be plenty strong. -- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread... |
160 days ago |
When I worked at a cabinet factory, we put metal hardware drawer runners in. The pullouts fit between the face frames. This works fine. -- Berta in NC |
160 days ago |
If you are making new drawers and want to mount them to the face frames, there is an easy full extension slide with an optional face frame mounting kit. Look at figure 2 for what it looks like installed. You will need to use the correct slides for the kit. Here is the link: http://www.accuride.com/Resources/PDF/3832FFCK-R10-0708.pdf -- Oldworld, Fair Oaks, Ca |
160 days ago |
Hey thelt -- Jim from Heirloom Woodshop, custom furniture ,maker, woodworking school, heirloomwoodshop.com |
160 days ago |
In Udo Schmidt’s book on Building Kitchen Cabinets, he uses a U-shaped wooden frame to install side-mount drawer slides in face frame cabinets. -- Rich, Seattle, WA |
160 days ago |
I have seen what Richforever is talking about in Schmidt’s book and I agree that would be your easest & best option. -- Sell it here> http://woodworkerslist.com |
160 days ago |
I would like to know what these u shaped woodens framed look like. -- Jim from Heirloom Woodshop, custom furniture ,maker, woodworking school, heirloomwoodshop.com |
159 days ago |
a1Jim, it’s not the face frame that’s 1/4”. It’s the side panels of the cabinet. The face frame is 3/4”. But I see what you are talkiing about doing and that may be a solution. John, I also like your link to Accuride, but that would mean I couldn’t use the existing drawer slides I already have. But I haven’t ruled out just buying new slides too. I haven’t seen Schmidt’s book and I’m not sure what rich and sandhill are talking about. Maybe somebody has a drawing of these U-shaped wooden frames. -- There are three signs of old age. The first is loss of memory. I forgot the other two! |
146 days ago |
here are links to some slide hardware from lee valley that should work |
146 days ago |
Check out Rockler woodworking for hardware needs. They have some great stuff, and you’ll get ideas just from looking at their selection. As for matching stains, my way of doing this if you’re thinking of shelac or a poly finish -- PJM.`·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((º> ""BY HAMMER AND HAND ALL ARTS DO STAND""1785-1974 nyc Semper Fi, Patrick M |
132 days ago |
The easiest way is to use L brackets to mount your sliding drawers to the exisiting cabinet shelves. No need to modify anything and they are the strongest way to mount. |
131 days ago |
Thanks, slideoutshelves! That will work for the bottom shelf just great, but what do I do for the top shelf? -- There are three signs of old age. The first is loss of memory. I forgot the other two! |
131 days ago |
If you have shelves in the top currently, the L brackets can be used there also. If there is no shelving, use the rear sockets. |
| Forum | Topics |
Woodworking Skill Share
2928 |
3961 |
258 |
955 |
226 |
Woodworking Trade & Swap
623 |
Coffee Lounge
2398 |
LumberJocks.com Site Feedback
524 |
