| Forum topic by Neodogg | posted 160 days ago | 588 views | 0 times favorited | 20 replies | ![]() |
160 days ago |
160 days ago |
tap it back and forth , ( not on cutter knife ) as you turn it . -- david ,new mexico ,allheart |
160 days ago |
I’m with Dave just tap it with a peice of wood on the side(s) -- Jim from Heirloom Woodshop, custom furniture maker, woodworking school, heirloomwoodshop.com |
160 days ago |
is this a common thing to happen? -- If you can't fix it with a hammer, you've got an electrical problem! |
160 days ago |
looks like it got some sap in it , or if it sits awhile it can pick up moisture from the air and rust toghether . -- david ,new mexico ,allheart |
160 days ago |
If the bit is broken. Screw the bit in a vise and then lightly tap the collet. If you have a chunk of brass, it would be a great piece to tap, otherwise maybe a dowel of a block of wood. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
160 days ago |
Hit with penetrating oil and let sit for a couple hours. Tap as directed above. May help to bump the collet insert out then you can sit the bottom of the bit on a block of wood then tap the insert from above with something non-marring, wood, brass, leather hammer etc. Bits usually get stuck because they are bottomed out in the collet then tightened. Always pull the bit up and 1/8 inch or so before tightening. Good luck, BTKS |
160 days ago |
I’ll ditto BTKS and do not overtighten. This also causes collets to stick like that one. -- Jerry--A man can never have enough tools or clamps |
160 days ago |
When I get a bit that is difficult to remove I take the collet off and tap the bottom of the bit with a wooden dowel. This has always worked for me. I also use “O” rings on the router bit shaft to keep them from seating too deep. You can buy 1/2” and 1/4” inside diameter o rings from the big box stores plumbing department for about $2 for about 20 O rings. -- Each and Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. Greg Little |
160 days ago |
If the above suggestions do not work, clamp a 1/4” open end wrench in a vise. Remove the bit and collet and slip the bit’s shank (bit facing down) onto the wrench. Take a (flat) 3/16” or 1/4” punch and insert it through the bottom of the collet until it contacts the base of the bit’s shank. Tap gently with a hammer until the bit drops out. Good luck. -- Dave; Lansing, Kansas |
159 days ago |
Hi Neodogg, A frozen bit is usually caused by one of two things. Corrosion or a burr that has formed on the shank of the bit. -- Keith, Charlotte, MI www.julyswoodworks.com www.TheBenchDawg.com |
159 days ago |
Another way is to put the spindle nut back on, put a wrench head or two betweein the spindle nut and the bottom of the bit, then unscrew the nut to apply upward pressure (while holding the shaft of course). |
159 days ago |
Try spraying some lubricant (teflon would probably best) then tap the collet. Once you do get it out, be sure to clean the collet and inside the spindle really well to help prevent it from getting stuck a second time. If the bit is stuck in the collet, simply put it in a vice and tap the bottom of the shank with a punch and mallet. -- "At its best, life is completely unpredictable." - Christopher Walken |
159 days ago |
I had exactly the same problem with an old router I had.I eventually heated it with a hot air gun paint stripper type .Theres no need for flames etc just warm it up the expansion will cause it to free .Alistair -- excuse my typing as I have a form of parkinsons disease |
159 days ago |
sorry for the off-topic comment, but i am a dog lover (and more specifically a boston lover! i have one, he is my baby lol) and i just had to say, that is one gorgeous boston….champion sired i assume? would like to see more pics of the little guy if you have em =) as for the thread topic, i’ve had it happen a bunch of times…these guys all give great advice and i don’t have anything i can add on…hope you get it worked out! i know how much it sux to try and work but you can’t use your tools! ahhh, it’s the worst! even more than having all the tools ‘n not doing anything with them i think….lol |
159 days ago |
A trick I use with the old abused routers at work it to leave the above mentioned gap. I go a little more than the above 1/8th of an inch. When I simply can not get the bit out of the collet, the I carefully hit the bit down into the collet. 9 out of 10 times this does the trick. -- P.O.C. |
158 days ago |
Ok, my two cents, :-) when I get a bit stuck, usually in my laminate trim router, I leave the collet nut on, but loosen it, then I take a small finish hammer and tap the nut on all four sides (also helps if you have the router so that the bit is hanging down) for me this has always worked. If the bit stays stuck in the collet itself, some penetrating oil normally frees that up. -- James |
156 days ago |
the day is mine! I got the bit out! I sprayed some wd-40 and let it sit over night, then this morning I taped it ever so gently with a punch and out it popped! Thanks to all you made suggestions. -- If you can't fix it with a hammer, you've got an electrical problem! |
155 days ago |
Neodogg, I am very happy that you got the bit unstuck, however I have a reccomendation so that this does not happen again. Happy routing. |
155 days ago |
Thanks jerryz for the insight, I’ll try it, sounds logical -- If you can't fix it with a hammer, you've got an electrical problem! |
155 days ago |
Tap a tapered screwdriver in the slots of the collet, this should help wedge it open.. Also make sure the inside of the collet is clean. Clean it out like you would a gun. -- -** You are never to old to set another goal or to dream a new dream ****************** Dick, & Barb Cain, Hibbing, MN. http://www.woodcarvingillustrated.com/gallery/member.php?uid=3627&protype=1 |
| Forum | Topics |
Woodworking Skill Share
2924 |
3954 |
257 |
952 |
225 |
Woodworking Trade & Swap
621 |
Coffee Lounge
2396 |
LumberJocks.com Site Feedback
524 |
