Creating Printable Patterns
Forum topic by Eric posted 03-22-2015 12:45 AM 1032 views 0 times favorited 7 replies Add to Favorites Watch
View Eric's profile
Eric
221 posts in 2476 days
03-22-2015 12:45 AM
How can I make a printable pattern from a photoshop (jpg) file. I have drawn some curves for sleigh bed legs using photoshop and would like to print the pattern in full scale multiple sheets with those little target things to line up.
-- Eric
7 replies so far
View NoThanks's profile
NoThanks
798 posts in 1494 days
#1 posted 03-22-2015 01:21 AM
Not sure how big they have to be, but you should be able to go to a copy shop, (kinko’s) some (Office Depots)etc,
and they can copy your picture and blow it up for you, again depending on the size you may be able to get it on 1 page. If not they should be able to tile it for you.
-- Because I'm gone, that's why!
View JAAune's profile
JAAune
1788 posts in 2282 days
#2 posted 03-22-2015 01:25 AM
Pictures can be imported into Sketchup then traced around. Sketchup has a tile printing feature.
Of course if you’re going to do that, it’s probably easier to just make the curves inside Sketchup to begin with.
View MrUnix's profile
MrUnix
6587 posts in 2164 days
#3 posted 03-22-2015 01:33 AM
I’d just open it up with your image processing software, scale it to size and print.. I do it all the time for scroll saw patterns. One pattern, can be scaled to whatever size blank I would like to use or happen to have; multiple times and multiple sizes.
PS: If it needs to spam multiple sheets, scale to full size and then crop out each page individually.
View Lifesaver2000's profile
Lifesaver2000
551 posts in 3077 days
#4 posted 03-22-2015 06:29 AM
This might do what you want.
http://woodgears.ca/bigprint
The eval version is free and will give you an idea if it will work for you.
View redryder's profile
redryder
2393 posts in 3067 days
#5 posted 03-22-2015 10:57 AM
I can see that woodgears web site above could have a lot of applications for wood working…...............
-- mike...............
View Holmer's profile
Holmer
11 posts in 3063 days
#6 posted 04-07-2015 02:48 AM
I found a overhead projector on craigslist for 20 bucks, I just print stuff out and then make copies onto transparency paper and blow it up on the wall and make it what ever size I want too.
View ColonelTravis's profile
ColonelTravis
1756 posts in 1859 days
#7 posted 04-07-2015 04:17 AM
PS doesn’t have a tiling feature to do this. If I use PS for an outline, I save it as a PDF and use Acrobat Reader to tile (divide a large outline over multiple pages.)
