Kreg Problems
Forum topic by Beams37 posted 03-21-2015 10:03 PM 1383 views 0 times favorited 23 replies Add to Favorites Watch
View Beams37's profile
Beams37
166 posts in 1215 days
03-21-2015 10:03 PM
Hey guys,
Last time I posted, I got a ton of information, so I’m giving it another shot.
Today, I bough a Kreg set up. Overall, I am very happy. However, I must have sheared off like 6 screws. For this project, it wasn’t as big of an issue, bc I just cur the board and started over. But, this could be a major issue down the road when I’m working on something nicer.
Any ideas? Am I doing something wrong? Wrong species (Hickory)?
-- FNG ... On a quest for knowledge.
23 replies so far
View ScottKaye's profile
ScottKaye
648 posts in 1978 days
#1 posted 03-21-2015 10:20 PM
Hickory if a very hard wood. Are you using actual Kreg Screws and not imitations? maybe try a quick stroke of the screw down a wax brick
-- "Nothing happens until you build it"
View CharlesA's profile
CharlesA
3329 posts in 1822 days
#2 posted 03-21-2015 10:25 PM
I haven’t had a problem with sheared screws, but when I use pocket holes in plywood or mdf I make sure I have the clutch set on my driver so it doesn’t overtighten. Might try that in hickory.
View txn's profile
txn
139 posts in 1484 days
#3 posted 03-21-2015 10:30 PM
Are you using the fine screws for hardwood? There are fine and coarse kreg screws coarse for softwoods (pine, cedar and poplar etc) and fine for hardwoods.
Beams37
#4 posted 03-21-2015 11:13 PM
Scott – They are the real deal Kreg screws. Wax isn’t a bad idea at all.
Charles – With the hickory, my highest clutch setting won’t even get close to getting in there.
TX – I am using the fine thread screws.
Maybe it’s just the hardwood … And my drill is lacking clutch settings … And a combination?
View txn's profile
txn
#5 posted 03-21-2015 11:28 PM
You aren’t by chance hitting a knot are you?
Beams37
#6 posted 03-21-2015 11:31 PM
Tx – No sir. No knots. It’s gotta just be the hickory … right?
View Troy Cleckler 's profile
Troy Cleckler
385 posts in 1396 days
#7 posted 03-21-2015 11:40 PM
Tx – No sir. No knots. It s gotta just be the hickory … right?
- Beams37
I would seem to think its the wood. I’ve not had that issue and I’ve been using the first edition since it came out. I’ve not used hickory but oak plenty of times and the other comments are correct, you need a clutch. Get use to it and you’ll wonder how you got along without it,
-- Troy. - Measure twice, cut once and fill the gaps....
View OSU55's profile
OSU55
1699 posts in 2014 days
#8 posted 03-22-2015 12:03 AM
It’s the hickory. Some of the oak I get can be very hard as well. Try the wax, and turning the screw a couple turns, back it out a turn, few more turns in, back it out a turn or so, etc. I find the self tapping screws go in a lot easier in hard woods this way. And, watch screws near the end grain/end of a board – in hardwood they can split the board w/o predrilling.
18351 posts in 1881 days
#9 posted 03-22-2015 12:33 AM
I would add, make sure your pilot hole is going all the way thru and use a shorter screw if you can.
View distrbd's profile
distrbd
2252 posts in 2471 days
#10 posted 03-22-2015 12:41 AM
I would switch from pocket screw to another form of joinery like dowels.
I have broken a few pocket screws myself when I was using hard maple,after having some success with waxing the screws,pre drilling,I couldn’t spend more time and energy fiddling with the Kreg jig,so I used dowels and got the job done,the piece I was working on looked just as good as if I used pocket screws.
-- Ken from Ontario, Canada
View mramseyISU's profile
mramseyISU
534 posts in 1570 days
#11 posted 03-22-2015 01:57 AM
Maybe switch to the course thread screws. One of them is meant for harder woods and one for soft woods and plywood but I can’t remember which is for which.
-- Trust me I'm an engineer.
CharlesA
#12 posted 03-22-2015 01:59 AM
coarse thread for soft (and plywood and MDF), fine threads for hardwood. That being said, still worth trying the coarse thread.
View Redoak49's profile
Redoak49
3283 posts in 2013 days
#13 posted 03-22-2015 02:51 AM
I think you will need to drill larger pilot hole. You may also encounter cracking..good luck.
View JAAune's profile
JAAune
1802 posts in 2342 days
#14 posted 03-22-2015 03:01 AM
I’ve used pocket holes on hickory before. It works but auger tip screws are a big help and you have to drive the screw in and out in short increments (about a 1/4” in, back an 1/8” and repeat) to do it without splitting. That gives the auger point a chance to drill a pilot hole.
View exelectrician's profile
exelectrician
2327 posts in 2452 days
#15 posted 03-22-2015 05:06 AM
Yeah… I had some of the heads pop off 3 months after the project was finished,,, the Kreg screws are weakly made
-- Love thy neighbour as thyself
