Glass doors HUH?????
Forum topic by skeeter posted 162 days ago 320 views 1 time favorited 11 replies Add to Favorites Watch
View skeeter's profile
skeeter
78 posts in 239 days
162 days ago
Topic tags/keywords: shaker glass door cabinet question cherry
So I am designing this dvd cabinet for a client who just recently purchased another piece from me.http://lumberjocks.com/projects/17402 . The cabinet will be cherry and it will be a massive 6 feet tall and 5 feet wide. I have the sketchup drawing if anyone cares.http://sketchup.google.com/3dwarehouse/details?mid=c7db0d0ac7a24504c938b3ed4b193fa0 Anyway I thought the project was moving along nicely until I read an Andy Rae article in one of my FW’s. He said good door building starts with good design. He also made a rule that a door shouldn’t be over 24 inches wide and over 4 feet tall. I said S%$T!!!! He threw a wrench into my project. Well, that is fine anyway because I already had a question about the glass anyway. How thick should it be. I thought 3/16 would be right but I don’t even know if they sell that size. I thought 1/4 would be too heavy and 1/8 would be too flimsy. Has anyone of my lumberjock commrades ever made a door 29 1/4 wide by just shy of 6 feet? Please tell me if I am making a complete blunder or if I should tell my customer we should make the width 4 feet, maybe alittle taller, and with 4 doors(one over top of a smaller one). Thanks for reading and hopefully replying.
-- My philosophy: Somewhere between Norm and Roy
View cabinetmaster's profile
cabinetmaster
8713 posts in 457 days
162 days ago
I would make my doors no bigger than 48”. Making a door that tall is asking for problems. It would be hard to keep a door that tall from warping. We always use 1/8” glass in our glass doors and apply a 1/4” X 1/4” strip behind it and they seem to work fine. Been doing this for years with no problem.
View kolwdwrkr's profile
kolwdwrkr
2253 posts in 489 days
162 days ago
291/4×70” is a big door. LOL. Put some glass in there and it will be a big heavy door. I’d say ad a stationary shelf and split the door and make it 35” tall or so. You don’t have to split it in the middle but I wouldn’t go any bigger then 40 or so. I agree 100% that a door shouldn’t be over 24”, in fact most companies don’t even guarentee a door bigger then 24”. 1/8” glass is standard. Instead of making a pair of doors why not have 6 doors ~ 20” x 35”
17054 posts in 476 days
162 days ago
I”m with both guys 1/8” glass and split the door in to two doors. Use some strong joinery M&T ,halflap or saddle joinery, It would’nt hurt to pin it also.
View ajosephg's profile
ajosephg
443 posts in 459 days
162 days ago
You should also strongly consider tempered glass so in the event it breaks it won’t throw off long shards which could cause serious injuries or death. There may even be some obscure law to that affect.
Need to have a serious discussion with your local glass purveyor.
-- Joe
View Jojo's profile
Jojo
581 posts in 870 days
162 days ago
Can it be done successfully? Sure.
Check what Todd says in the third picture’s caption over here in the FWW Gallery.
I quote (sic):
”The large opening and the door hardware made for a technically challenging install.
It is like shooting a rifle, the farther down range the bullet flies, the further off the mark it gets. I had to get these doors to all meet in the center over a 7’ span.
The meticulous planning and tedious work paid off in the end.”
Is it a sure way of making your life harder? Of course it is!
But life wouldn’t be the same without those challenges, wouldn’t it? I say go for it but take your time to plan carefully. By the way, don’t hesitate to contact Todd and ask him about the technical challenges of such a job, I’m positively certain he’d be glad to help you through it. I don’t know any other person more willing to help spread the knowledge of his craft than him.
I also second Joe’s advice, I wouldn’t do it with any other kind of glass. Think about liability and your insurance coverage.
-- Jojo, shopless in Kyoto ยท http://twitter.com/kagushokunin
View Kent Shepherd's profile
Kent Shepherd
840 posts in 185 days
162 days ago
We frequently make glass doors taller than 48”, but I don’t like to. I would not make one that wide. Often we put a rail in the center to help stability and stength, but it does not help warping. We won’t guarantee large doors, except to guarantee they will warp, more than likely.
That said I pretty much agree with what has been said already
View LesB's profile
LesB
555 posts in 341 days
162 days ago
Looks like everyone has covered the topic. I just want to repeat the caution about using tempered or safety class for a door that big. It will almost certainly get broken some day. Also tempered glass is harder to break. I’m not sure you can get it in 1/8” however.
-- Les B, Oregon
skeeter
162 days ago
I am going to make pinned mortise and tenon joints so that is not a problem there. Kolwdwrker how would I make it with 6 doors. Not following you there. Would a bi fold help or hurt? It still has alot of pressure on the hinges if not more.
kolwdwrkr
162 days ago
Instead of having you partition centered, off center it. You could even have 2 partitions, but it’s not necessary.
View LesB's profile
LesB
161 days ago
I happened to be in a glass store today and they can make tempered glass in 1/8” thickness. The edge is still fragile so it would definitely need a frame to protect it.
Have you considered having sliding glass panels?
-- Les B, Oregon
dennis mitchell
3791 posts in 1213 days
161 days ago
I make any size door I want. Try 6 inch stiles and 12 inch rails. Then again if I want the doors to all have the same size rails and stiles then the 2X4 guide line works.
