Dewalt 735 on Craigslist
Forum topic by Brian024 posted 1435 days ago 2226 views 0 times favorited 18 replies Add to Favorites Watch
View Brian024's profile
Brian024
358 posts in 1571 days
1435 days ago
I’ve been looking through Craigslist a lot lately, just see what is being sold. A couple days ago someone put up a Dewalt 735 Planer. I’ve been in contact with him and our plan is to meet later today to look it over. Anyways, is there anything special I should look for, besides things that look out of place? I won’t have the ability to run it because of where we are meeting.
http://martinsburg.craigslist.org/tls/1225231453.html
18 replies so far
View Julian's profile
Julian
880 posts in 1696 days
#1 posted 1435 days ago
I’ve had mine for over 5 years now and it sees tons of use. It’s had no problems as of yet, so I would assume that if it looks fine and not abused that you should be fine. The blades are the only thing that gets replaced frequently on mine.
-- Julian, Park Forest, IL
View Jacobsbrother1's profile
Jacobsbrother1
1 post in 1437 days
#2 posted 1435 days ago
Has Anyone used the Dewalt 734? It’s over $200 cheaper than the 735 and fits better into my budget. Or are there any suggestions for a different brand in the same price range (appx: $400).
Brian024
#3 posted 1435 days ago
I figure the one thing I’m probably going to have to do is replace the blades, but what he has told me it is in good shape and has seen about 30 hours of use.
View RedShirt013's profile
RedShirt013
219 posts in 1832 days
#4 posted 1435 days ago
The infeed/outfeed tables is an accessory not included with the planer, but incredibly useful so if he has it make sure you get those. Otherwise what comes to mind, without getting to run test pieces, is to turn the handcrank and adjust the height of the planer to check if there’s any racking from previous abuses. Also the 735 comes with two different DC port accessory, one that directs the sawdust downward (imo rather useless), the other converts it to a 4” port, which will come in handy so get that from him too.
-- Ed
Brian024
#5 posted 1435 days ago
Thanks Ed, yeah I will definitely get the tables. I hear it has a blower for the saw dust so if its possible I might hook up a line and run it to a trash can or some container. I figured for $300 atleast take a look at it, when its $600 new.
View ChuckV's profile
ChuckV
1753 posts in 1698 days
#6 posted 1435 days ago
The planer comes with a T-shaped hex wrench that is stored in the lid of the machine. The wrench also has some magnets in the handle to help in changing the blades. It looks like it is missing in the second photo. Not a huge deal. But, you might want to take a set of hex wrenches with you so that you can peak inside for any obvious signs of trouble. There are four bolts in the silver pieces that you see on the top.
I like my DW735 a lot. If this one is in good shape, that is a great price.
-- I was walking down the street, something caught my eye, and dragged it 15 feet.
Brian024
#7 posted 1435 days ago
Thanks Chuck, I will remember to bring them with me.
Brian024
#8 posted 1435 days ago
Well guys, I’m now the new owner of a Dewalt 735. This is one heavy beast though, almost 100 pounds but it is awesome. It’s a little beat up but it runs very well. I’m pretty sure I need to change the blades or atleast flip then over because I’m getting nicks in the wood like some people describe. But overall ,very happy with this. Now just need to build a cart and connect it to a dust collector.
ChuckV
#9 posted 1435 days ago
Congratulations! I am sure that you are going to enjoy the planer.
Brian024
#10 posted 1430 days ago
Ok guys, I ran into my first problem, I was wondering if anybody has had this problem. Today I went to plane down some 1X pine and was cranking the handle down and it got about 1 1/2” and it started to squeak, I then sprayed some lubricant on each of the 4 posts and got it to go away. As I got farther down to around 1”, it began the squeak again and the handle became very hard to turn, then eventually I couldn’t turn it, it would go up but not down, past about 1” or so. Now I did the same planning the other day and it worked fine, but today its giving me trouble. I heard of someone saying that sawdust and chips might get in the gearing that runs along the post, could that be the problem?
View juniorjock's profile
juniorjock
1774 posts in 1936 days
#11 posted 1430 days ago
It could be saw dust. What is the depth of cut gauge stop (or whatever it’s called) set at? You may have moved it by accident. If it’s on 1-inch, it won’t go any lower.
Edit: There’s a sprocket chain and some cogs that do the actual raising and lowering I think. The post are guides. It’s been a while since I had the cover off mine, but that’s what I remember.
Brian024
#12 posted 1429 days ago
That would be the problem Jr. I completely forgot the planner had the preset depth’s, I guess I reset it to 1 1/4” after the other day. Thanks, now to just remember in the future.
juniorjock
#13 posted 1429 days ago
Glad you got it figured out. I’m sure you’ll love your new machine.
View Rj's profile
Rj
1036 posts in 1802 days
#14 posted 1429 days ago
When the blades get nicked just move the blades right & left= 1st one to the right then the second one to the left and the 3rd blade to the right= so the nicks don’t line up (it only takes a slight adjustment this will prolong the use of the blades) . I’ve had my 735 for about 5 yrs and its still doing a great job the only thing is the blades do nick pretty easy .
-- Rj's Woodworks,San Jose & Weed Ca,
View Greg The Cajun Box Sculptor's profile
3779 posts in 1479 days
#15 posted 1429 days ago
I’m not sure which woodworking magazine I saw it in but one recently had an advertisement for a much thicker and improved set of steel replacement knives for the Dewalt 735 planer. Just might be the way to go when you need to replace the blades. Another manufacturer makes a spiral cutterhead with replaceble carbide inserts for the 735, however I would imagine they would not be cheap.
-- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com
