Trimming Laminate When There's No Room For Router Bit
Forum topic by Adamal posted 03-20-2015 04:43 PM 1186 views 0 times favorited 7 replies Add to Favorites Watch
View Adamal's profile
58 posts in 1933 days
03-20-2015 04:43 PM
I’m going to be putting new laminate on my pool table, but the upper edge of the sides won’t let me use a router bit with a bearing on it. The little ledge you see is only 1/4” deep.
Any ideas on a good way to trim the laminate on this edge? Would a draw-knife work. Or should I just try to line up the factory edges to avoid having to trim?
7 replies so far
View waho6o9's profile
8130 posts in 2509 days
#1 posted 03-20-2015 04:46 PM
We used a file and trimmed it flush with blue painters tape
on the front of the file to avoid damage to other surfaces.
Tedious but effective.
View dtsdig's profile
8 posts in 1098 days
#2 posted 03-20-2015 04:55 PM
I have seen some folks have good luck with this one:
One person I know even ground down the rounded tip so that he could get into even shallower recesses.
View jdh122's profile
992 posts in 2750 days
#3 posted 03-20-2015 04:58 PM
A spokeshave might work. Drawknife’s not a great idea – the handles will be in the way and too easy to slip, I think.
-- Jeremy, in the Acadian forests
View BinghamtonEd's profile
2286 posts in 2302 days
#4 posted 03-20-2015 05:29 PM
What if you installed it, then clamped a board (as thick as that recess) to the vertical section above it, then use a router with a dado cleanout or bow/tray bit to trim it flush to the piece you clamped on?
The clamped on piece would serve as the surface to reference your router on. Instead of the normal way of trimming it (router vertical and using the side of the cutting bit), router would be held horizontal and the depth set so the bottom of the bit is equal with the router base.
Edit : Just noticed the rounded corners. You’d probably need to do some hand work for those, but if it’s just the corners, a block plane and some sandpaper could work for those.
Craftsman on the lake
2770 posts in 3370 days
#5 posted 03-20-2015 05:31 PM
This is what I used to do long before I had a router. Glue some good sandpaper on a 1/8” disk about the diameter of a sawblade. Put it in your table saw with the paper facing the saw fence. Cut the laminate almost the proper width and run it through the sander in increments till you get it exactly the width that will fit the space you need to cover. I did this and then eventually went to a thick aluminum disk. I did a lot of kitchen counters that way.
A file for some edges works too.
View Earlextech's profile
1160 posts in 2623 days
#6 posted 03-20-2015 05:48 PM
Mica file
#7 posted 03-20-2015 07:09 PM
Thanks all.
I like the idea of using the router vertically. If I used a bushing and the right bit, I wouldn’t even need to clamp anything down.
Now, how do I do the corners… I must formulate another question.
