Panel Cutting - Track saw vs Panel Saw?
Forum topic by reggiek posted 164 days ago 642 views 0 times favorited 13 replies Add to Favorites Watch
View reggiek's profile
reggiek
716 posts in 168 days
164 days ago
I am currently evaluating tools to cut panels down to size. Panel saws are mostly expensive….there are good plans for making one – but are they worth the time? I have seen the Dewalt track saw (does anyone have one? whats your call on it?) being advertised and also a similar saw from Festool (very expensive – more so then even the panel saws I’ve priced).
A good ol circular or worm type saw does the trick…but are extremely hard to get a straight line this way…even with templates clamped to guide the saw.
Anyone have some input?
View Don K.'s profile
Don K.
1095 posts in 225 days
164 days ago
reggiek,
Welcome to LumberJock’s !!! I personally do not have either (Panel or track saw). But I have seen some remarks about some track saw’s on here. Every one I have read have nothing but good things to say about them. One member (His name escapes me at the moment) said he does not even use a Table saw any more since he started using a track saw.
I am personally thinking of getting me a Dewalt track saw myself….they look like a pretty good set up.
-- Don S.E. OK
View KevinM02's profile
KevinM02
3 posts in 317 days
164 days ago
reggiek,
As a vendor for all three manufacturers of the track saws on the market (Makita has one coming out in the near future) they are all excellent machines. I have used both the Festool and the Dewalt, and given the choice I would get the Festool. The Festool has a better track (less flex and better material), a variety of track lengths, and tracks can be connected and still maintain accuracy. The Dewalt is by no means a bad machine, but at $499 for the Dewalt and $500 for the Festool, I personally would spend the extra dollar and get the Festool. But I think you would be pleased with either machine.
View daveintexas's profile
daveintexas
338 posts in 774 days
164 days ago
Well since you asked…...........
I had a SawTrax. It was very good at breaking down large sheets of plywood. And for the most part was accurate. The down sides for me were space, it uses a large footprint. And one you broke down the sheet of plywood, it still needed to be recut to get a smooth, chip free edge. Suffice to say I sold it.
I did some research and ended up with the Festool and the t55 saw. It cuts great, gives me a smooth, chip free edge and I go from cutting down the sheet to finished cut in no time. Yes, it does require some place to lay the plywood sheet on, and some folks have used folding saw horses with good success. I bought a 4×8 sheet of the pink styrofoam insulation. When i need to cut down sheets, I lay the styro sheet on the work bench, throw the sheet of plywood on it and cut away. When done, i stow the styro sheet under the workbench.
One additional benefit that convinced me to but the Festool, is that with the zero clearence strip i get no chip out and can use it for batch cutting veneer. Works super.
I have seen the T55 and rails used on ebay.
Dave
-- MISSION FURNITURE-My mission is to build furniture
View 747DRVR's profile
747DRVR
47 posts in 255 days
163 days ago
I also have the Festool and love it.The finish cut is absolutely splinter free and set up is so easy.I have 2 of the 52”(?) rails with connectors to make the 8’ rips.
View James's profile
James
161 posts in 179 days
163 days ago
just build jourself an outfeed table along with a wing extension, wayyyyy cheaper.. use it as a workbench & assembly area when not cutting, put it all on locking wheels to move against wall when not working.. just my cheap view ;)
-- James, Bluffton, IN
reggiek
163 days ago
Yep….I broke down and got the Festool….After evaluating the model 75 and th 55, I opted for the smaller and lighter 55. The shop was out of the 55” rails that come with it…so he gave me a 75”. They also have a promotion going on that gets you an assortment of blades and free clamps. I am hoping to try it out this week when I have to cut some bottoms for a set of bins I am making. Also, I have some sideing to cut for a lawn tool storage room I put together.
I also got some extension clips and a 32” rail to make the tool able to rip 8’ panels.
This is the first Festool I have bought….I have heard alot about their innovation…but have found them kind of pricey…
2461 posts in 239 days
163 days ago
kevin you convinced me to go with the festool !
for 1dollar how could i miss ?
thanks guys ,
good post .
17048 posts in 475 days
163 days ago
Even though I don’t own either tool I feel that most woodworkers would do better to spend there money on a table saw if the don’t have one or a jointer or routers or a band saw etc. Even though both these systems cut panels fairly well (from what reviews say)You can’t make 10 or more sleds to do any number of operations on, or use a dado blade on them like you can on a table saw. I feel they might work well if your building cabinets on site which most people don’t do any more or some other operation that requires a lot of ripping on site. The only other purpose I can see to have these systems is if you can not physically lift and move sheet goods through a table saw an then still you will have a problem just moving the 60-80llb sheet goods any way.
747DRVR
163 days ago
Congrats reggiek,You are going to love that saw
View cowdog80's profile
cowdog80
32 posts in 45 days
40 days ago
I never was the world’s biggest track saw fan until I got a dewalt track saw
-- http://woodworker.com
View Old's profile
Old
14 posts in 54 days
40 days ago
I don’t have either, but found this online that might help???
http://www.familywoodworking.org/forums/showthread.php?t=11263
View CessnaPilotBarry's profile (online now)
CessnaPilotBarry
1290 posts in 601 days
39 days ago
I don’t see why you’re having problems with a circular saw and guide. I would spring for a track saw in a moment if I didn’t get good results with my circular saws and shop made guides.
My secret? I cut the panel flat, on a 1 1/2-2” thick foam insulation bed. I can lay it out, kneel on it, etc… all to great precision.
I WOULD consider a panel or track saw, if I didn’t have a table saw and/or dust collection was my top priority.
But to simply break down sheets?
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
View gerrym526's profile
gerrym526
139 posts in 707 days
38 days ago
I have to agree with Barry.
Have been cutting cabinet grade ply panels for years with good results, using an inexpensive guide and a $60 Black and Decker lightweight circular saw-equipped with an expensive blade ($30).
If you position your cutting guide off one of the factory finished edges, your cuts will be on line.
If this doesn’t work for you, just cut the panels 1/4” wider, and rip to width with the factory edge against your table saw fence.
-- Gerry
