Homemade welded mobile base - anyone?
Forum topic by MrUnix posted 03-20-2015 07:30 AM 5124 views 0 times favorited 25 replies Add to Favorites Watch
View MrUnix's profile
MrUnix
7105 posts in 2434 days
03-20-2015 07:30 AM
I was wondering if anyone has welded up their own mobile base for a table saw, or really any heavy machine in your shop. I’ve got a ton of old bed frames out in the shed and would like to put some of them to good use! Would love to see what others have come up with so I can get some ideas on a design.
25 replies so far
View Quanter50's profile
Quanter50
278 posts in 2531 days
#1 posted 03-20-2015 09:40 AM
Bed frame steel seems like it would be too light. I used square tube steel and welded my own brackets for the wheels. My welding skills are pretty bad, but I managed to make a nice frame. I was pretty proud of myself when I was done. Here it is?
View JoeinGa's profile
JoeinGa
7739 posts in 2242 days
#2 posted 03-20-2015 12:24 PM
I think that so long as the bed frames are angle iron, they will more than likely work fine. Years ago I built a light duty trailer from old bed frames that I pulled with my pickup. I had cross-braces every 12” along the length and used 2” X 12”s for the decking. I used it to haul riding lawnmowers, lumber and even helped a few friends move with it. I had it almost 5 years till someone offered me more than I thought it was worth, To coin a phrase, “He made me an offer I couldn’t refuse” :-)
I would overlap the corners (rather than just butt-weld them) and make sure to use cross-pieces along the length. On the short ends, I would cut a piece in half longwise, and use the flats as a filler so all four ends/sides were touching the base of the saw.
View isotope's profile
isotope
177 posts in 1859 days
#3 posted 03-20-2015 01:03 PM
When shopping for a SS saw and researching mobile bases, I came across a very well done example by a fellow LJer. I’ve taken the liberty to link to the blog here.
View bonesbr549's profile
bonesbr549
1579 posts in 3302 days
#4 posted 03-20-2015 01:19 PM
Go to the verysupercool tools guy and he’s a big welder, and has done one and talks about it on youtube. I think that if you have the skill tools and steel laying around it’s great, but for the cost, you just can’t beat the SS heavy duty base. It’s fantastic.
View Minorhero's profile
Minorhero
373 posts in 2840 days
#5 posted 03-20-2015 02:06 PM
If you can do it out of existing steel then its definitely worth it to give it a shot. If you have to buy angle iron etc form any place that is not a junk yard, you will likely end up spending more then the cost of a commercial mobile base. I am a huge fan of the shopfox mobile base which is a great size for table saws. http://www.amazon.com/Shop-Fox-D2057A-Adjustable-Mobile/dp/B0000DD6B9
I own 4 of them now, one I swaped out the bars for longer ones and I use on my lathe. Couldn’t be happier with them.
MrUnix
#6 posted 03-20-2015 07:23 PM
I think the bed frame angle should work… heck, it can take the bouncing around of some pretty large people on king size beds, so I don’t think a 500 pound or so load in a relatively small footprint would be too much :) Plus, I have a bunch of 1/4” plate that I most likely will be using in the corners, and can use for mounting the casters. I have thought about making it with two fixed and two swivels… maybe even making the two fixed wheels out of HDPE from milk jugs, but at this point it’s all up in the air as to what I’ll wind up doing.
I’ve also thought about buying new (less work!), or using square tube… but I have about a dozen bed frames just piling up and would like to do something with them. My welding isn’t exactly the prettiest, but nothing has come apart yet! I have a Millermatic 210, which has easily handled everything I’ve thrown at it so far.
How did you handle locking it in place? Did you use locking casters or some other method?
View REO's profile
REO
929 posts in 2309 days
#7 posted 03-21-2015 12:32 PM
I have a 22’x24’ shop. I have one fixed bench of 36” x 8’ with the compressor underneath. There is a drawer 12” x 36” x 6’ that rolls on the floor that houses most all the power hand tools. I have a shelf around two sides that leaves just enough space between the ceiling and shelf for plastic totes. I have a Bridgeport mill, a chucker lathe and a sag 14 lathe for metal work that dont move along with a 12×42 wood lathe and a 24×84 wood lathe. the rest of the tools in the shop, are in work cells that move on wheels. cell one is the welder cart: Mig, Tig, Plasma cutter, and Oxyacetylene. which gets stored in the garage proper for the most part but gets used in the shop space during a build. Cell two is the drill press and band saw back to back and a shaper on the out-feed side of the band saw. Cell three is the table saw, router table, flip up planer and an “appliance lift” for the sander. with the planer inverted and the outfeed section it also provides a large work surface. I have a wing assembly table that is 48” x 16 feet that is KD so I can store the parts hanging on the wall. The “anchor” end of the wing table is a 48”x 32 bench with a 36” roll, shear, brake. and the tower attachments for rigging the biplane wings. With the cells against the wall I can still walk around the table and work on a set of wings. the bed frames will master the weight if done well the welds can become the weak point because the bed frames I believe have a higher carbon content and will em-brittle in the HAZ. (they are more like spring steel than plain hot or cold rolled steel) I would sling it low and use dog style clamps for the feet instead of lift out of the way casters or locking casters.
View lndfilwiz's profile
lndfilwiz
108 posts in 1836 days
#8 posted 03-21-2015 12:51 PM
How big is your welder? Build a mobile base for my mig welder with an old shopping cart!
-- Smile, it makes people wander what you are up to.
View fuigb's profile
fuigb
540 posts in 3193 days
#9 posted 03-21-2015 01:17 PM
Google “New Chinky Workshop.” Sounds horrible, I know, but the site author is having fun with his background and is engaging in word play with a nod to Norm Abrahms. Anyway, the guy is a renaissance man who combines metal-working skills with carpentry. Good advice already posted above, but the other site is a good resource.
-- - Crud. Go tell your mother that I need a Band-aid.
View AlanBienlein's profile
AlanBienlein
159 posts in 2909 days
#10 posted 03-21-2015 07:27 PM
I made one for my jointer.
View weldoman's profile
weldoman
114 posts in 2293 days
#11 posted 03-22-2015 12:10 AM
http://lumberjocks.com/topics/47942 Here’s an old post of mine and a mobile base I made for a jointer.
-- missouri, dave
MrUnix
#12 posted 04-14-2015 06:10 PM
Thanks for all the suggestions everyone. This is what I got so far:
It’s 1-1/2” frame stock and since it was a bed frame, it’s a pretty strong high carbon steel… but it welded up really nice and wasn’t too hard to cut/drill. The base area is just a bit less than 21” square (to fit under a Unisaw which is roughly 20-3/4” X 20-3/4”). A piece of 3/4” plywood inside gives a nice solid area for the machine to sit on, as well as raise it up enough for the dust collection port on the bottom base to clear the side rails. Once the base frame was welded up, I added two fixed wheel mounts on one side to accept some 2” diameter wheels secured with 3/8” bolts:
I made the wheels out of HDPE, which I recycled from milk jugs, and then turned them on the lathe to the proper size. I didn’t want the base to sit too high, and this setup keeps it just about 3/4” off the floor.
The last thing I need to work out is how to do the caster(s) on the opposite side (and then paint of course!). Since I have fixed wheels on one side, the other side really needs to be swivels, and I also need to lock the base in place when not being moved. I’ve considered something like those foot operated lifting casters, but haven’t made any final decisions as of yet.
PS: @lndfilwiz – I like the shopping cart idea for a welder cart… but I’ve got a MM210 which has it’s own wheels so that wouldn’t really work for it :)
View Bluepine38's profile
Bluepine38
3380 posts in 3320 days
#13 posted 04-14-2015 07:25 PM
Table saw? #2: Almost finished cabinet saw.
The above title links to a blog on my cabinet saw. A welder is still on the list of tools to buy, so when I
needed a base for this saw, I went to a local steel supplier that has a large assortment of scrap and cut
steel available and bought a piece of 1/4” steel big enough that I could bolt some timber outriggers on
the sides and let me set the saw between them. I bolted some pieces of 1/4” plate on top of those
timber outriggers and bolted the heavy 5” casters to the plate. I sized the outriggers to make the
saw top a comfortable height for me. The steel base extended far enough to the side to put on
to special pads to lift and lock the base to immobilize it. I covered all the visible steel with wood. It
was done with the tools I had and was fun for me. One of my tools is a special metal cutting skil saw
that can cut up to 3/8” thick steel, without it this would not have been possible.
-- As ever, Gus-the 80 yr young apprentice carpenter
MrUnix
#14 posted 04-14-2015 09:45 PM
The above title links to a blog on my cabinet saw. A welder is still on the list of tools to buy, so when I needed a base for this saw, I went to a local steel supplier that has a large assortment of scrap and cut steel available and bought a piece of 1/4” steel big enough that I could bolt some timber outriggers on the sides and let me set the saw between them [...]
I thought about doing something with wood or wood/metal, but since I have so many bed frames just sitting around doing nothing, I really needed to figure out something to do with them :) (plus, I have the welder and don’t use it near as much as I should). I like your bolt/ratchet lifting idea and may do something similar as well. Would be pretty easy to weld on a couple of tabs for them off the side of the frame. What did you use for the pads/feet on the bottom of them?
PS: Nice saw… love the cast iron base!
Bluepine38
#15 posted 04-14-2015 10:03 PM
The company I retired from sold the special padded feet to one customer, so I bought a couple for my
own use. They were not expensive at the time, but the customer quit using them, so I will have to
figure out a way to make my own now.
