Stopping Tear out on Pine
Forum topic by EdsCustomWoodCrafts posted 03-19-2015 06:42 PM 1304 views 0 times favorited 10 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
766 posts in 1310 days
03-19-2015 06:42 PM
I’m looking for a solution … I’m going to be cutting 12” wide pine board on s table saw and I don’t want anymore tearouts…
I read a couple of solutions and I’m wondering if taping the board with tape at the point of entry and exit will work.. Other tried and tested options are most welcome
Thanks
Ed
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
10 replies so far
View HornedWoodwork's profile
HornedWoodwork
222 posts in 1181 days
#1 posted 03-19-2015 07:09 PM
A better saw blade would be the best option. If you are using the one that came with the TS that is likely the biggest cause. You could also try attaching a sacrificial board to the one you are cutting with double sided tape. It’s not the best solution but it will stop the tear out caused by the blade blasting out the end of the cut.
Maybe try raising or lowering the blade so that the gullets between the teeth work more efficiently (center the gullet) and that might help as well. Masking tape could help, but it’s not a real fix.
-- Talent, brilliance, and humility are my virtues.
View BinghamtonEd's profile
BinghamtonEd
2297 posts in 2337 days
#2 posted 03-19-2015 07:18 PM
I know it’s not pine, but I just got done cutting a whole lot of DF for my new bench top and vise jaws. I used Freud rip/crosscut blades and a ZCI, and backed up the piece on crosscuts. Cuts were very clean.
View greg48's profile
greg48
600 posts in 2724 days
#3 posted 03-19-2015 07:41 PM
Try a zero clearance throat plate on your saw table. A dedicated rip blade (thin kerf) is also recommended. I use a Freud, but they are a bit spendy.
-- Greg, No. Cal. - "Gaudete in Domino Semper"
View AlaskaGuy's profile
AlaskaGuy
4047 posts in 2276 days
#4 posted 03-19-2015 08:13 PM
Must me a saw blade or saw set up issue. I don’t get tear out when ripping pine.
View Ghidrah's profile
Ghidrah
667 posts in 1189 days
#5 posted 03-19-2015 10:09 PM
I have to ask what is your method for cross cut? Are you using the fence, miter gauge or panel sled?
Is the fence, miter gauge or panel sled square to the blade?
Does the miter gauge have a backer and is it or the sled set for a zero clearance cut at the blade?
If you’re using a panel sled and it is -0- to the blade then it doesn’t matter if the insert is -0- or not.
-- I meant to do that!
greg48
#6 posted 03-19-2015 10:19 PM
I have to respond back Ed, I was under the impression that you were ripping pine boards. If you are crosscutting, ignore my initial response. Build yourself a crosscut sled (2 runners)!! You’ll never regret it.
View Jim Finn's profile
Jim Finn
2647 posts in 2889 days
#7 posted 03-20-2015 12:46 AM
I would cut it with a sliding miter saw with a cross cut “fine cut” blade with a backer. I cut cedar and pine and fir like this all the time. I never cross cut on my table saw so I have a rip blade that gives me glue up ready cuts there.
-- Website is https://craftingcouple.com/
17955 posts in 1824 days
#8 posted 03-20-2015 12:52 AM
Crosscut blade like others have said. You shouldn’t get any tear out as long as you feed into the blade slowly. Tear out comes from teeth taking too big of a bite. That won’t happen with a good crosscut blade.
View Roger's profile
Roger
20923 posts in 2771 days
#9 posted 03-22-2015 11:53 AM
As many has said, a good x-cut blade and definitely need a zero clearance throat plate.
AlaskaGuy
#10 posted 03-22-2015 04:52 PM
Now that I realize your crosscutting and not ripping.
When I cross cut on the table saw I use a backer board on the exit side of the stock. It the same idea of using a backer board with make cope cuts for cabinet doors on the router table or shaper. Never have a problem with the entry cut …...
