| Forum topic by bayouman | posted 165 days ago | 216 views | 0 times favorited | 3 replies | ![]() |
165 days ago |
165 days ago |
No experience building my own, but have installed several. Some refits and some new construction. Are you talking swinging or overhead. Swinging can bet real heavy, would suggest some type of roller / support on swinging end to take a lot of weight off the hinges. Overhead doors, weigh them and get springs or torsion bars to match the weight. Torsion bars can be tricky and take out some teeth if you’re not sure what your doing. Linear springs do need a safety cable down the middle to arrest them when they eventually break. Another option, look at the old style pivot doors. The hardware may be near impossible to find but can be made out of readily available steel stock. Mostly angle iron and some bolts with large springs. I’m not sure how to measure and weight match that style. Also think the pivot style is really limited to size. OBTW, long strap hinges are on all the old barn doors around here. They eliminate a lot of torque on the hinge and hold over a large area. There is also the option of a left to right sliding door, like most barn doors today. Cannon ball track and a couple of hangers will have you in business. Only drawback, have to have room to one side to extend the track and a spot to slid the door. Can’t leave door open for long periods if it goes past the building, wind will wreak havoc and sometimes hold it closed when it’s blowing hard into the door. Ok, I’m finally done. BTKS |
164 days ago |
i had to make folding barn doors to a badly built barn . -- david ,new mexico ,allheart |
164 days ago |
Years ago I used the idea of building my own garage doors as an excuse to buy a new table saw. AFTER buying the saw I started talking to fellows who had actually built their own garage doors (roll-up overhead type), priced it out and then admitted defeat and bought insulated steel doors which I installed myself. (not a real tough job) -- Tom Hintz, www.newwoodworker.com |
| Forum | Topics |
Woodworking Skill Share
2928 |
3961 |
257 |
955 |
226 |
Woodworking Trade & Swap
622 |
Coffee Lounge
2398 |
LumberJocks.com Site Feedback
524 |
