Inherited a Practically New Delta 34-670...
Forum topic by aMomentOfScience posted 03-18-2015 02:58 PM 953 views 0 times favorited 5 replies Add to Favorites Watch
View aMomentOfScience's profile
aMomentOfScience
3 posts in 1508 days
03-18-2015 02:58 PM
... and I’ve purchased the Delta 36-T30 fence. I am trying to find the saw that it is a “Plug n Play” with RE: TS top dimensions and am having a very difficult time finding it. If anyone happens to know off the top of their head and could pass that information along I would be extremely grateful. Thanks in advance for any help.
-- "Never attribute to malice that which can be adequately explained by stupidity"
5 replies so far
View knotscott's profile
knotscott
7980 posts in 3343 days
#1 posted 03-18-2015 03:33 PM
Sorry for a being a little thick, but are you asking specifically for the table dimensions of the 34-670?
View TheFridge's profile
TheFridge
9249 posts in 1454 days
#2 posted 03-18-2015 04:15 PM
drill holes on an old saw isn’t hard at all.
aMomentOfScience
#3 posted 03-18-2015 06:16 PM
Scott… actually I am trying to determine the dimensions of whatever saw the 36-T30 bolts directly up to so I can build out my table (MDF) to that size so as to best fit the fence system. Depth (front to back) is the main dimension I am looking for. The 34-670 table is only 22” deep (if memory serves) and the fence is clearly made for a significantly deeper table. I was able to determine that the fence seems to be made for the Unisaw and the 5000 series saws after I posted this. But I am still curious the table depth that it is designed to be used on without any modification to the fence and namely the clip that grabs on the rear rail. (the outfeed side past the blade)
Fridge… You are correct. I have the angle iron bolted to the stamped steel extension wings temporarily and drilling the holes to do that was no task whatsoever.
Thanks to you both for the replies, gentlemen!
knotscott
#4 posted 03-18-2015 06:27 PM
The depth of standard full size table saw is 27”. In case it helps, here’s a link to a post from a guy who put the same fence on the same saw.
http://lumberjocks.com/topics/34712
aMomentOfScience
#5 posted 03-18-2015 11:27 PM
Thanks for the link, Scott! I’m sure this information will come to be quite useful.
