Best way to stop rust/corrosion??
« back to Coffee Lounge forum
Forum topic by YoungManJosh posted 06-15-2009 10:02 AM 1440 views 0 times favorited 13 replies Add to Favorites Watch
View YoungManJosh's profile
YoungManJosh
11 posts in 3267 days
06-15-2009 10:02 AM
Topic tags/keywords: question tip
I find in my small workshop, on some of the machinary that rust/corrosion is starting to be abit of a problem. I already use some spray which works for a certain period but its going to cost a fair amount of money to keep getting cans, so what are some tips or advice you have for this problem????
-- Im not insane, my mother had me tested.
13 replies so far
View Mike's profile
Mike
391 posts in 3614 days
#1 posted 06-15-2009 11:37 AM
Johnsons paste wax. Can goes a long way.
Other than gun socks for hand tools or an air dehumidifier system.
-- Measure once cut twice....oh wait....ooops.
27250 posts in 3819 days
#2 posted 06-15-2009 01:14 PM
I will echo Mike’s suggestion for wax. I use Renaissance wax. It is a little pricey but I bought a can three years ago and, even though I wax all my cast iron tops regularly, still have plenty left.
View rtb's profile
rtb
1101 posts in 3710 days
#3 posted 06-15-2009 05:14 PM
Defiantly wax. Almost any paste wax will do the trick clean the surfaces well first.
-- RTB. stray animals are just looking for love
View kerflesss's profile
kerflesss
182 posts in 3365 days
#4 posted 06-15-2009 06:17 PM
Hi YoungManJosh, dust is a contributor to rust as it picks up moisture and holds to the CI/Steel tops. Wax will help but needs to be maintained on a regular basis. On those tools you use sparingly I’d make covers of a breathable material. Plastic tarps don’t breath and trap moisture. Tyvek (house wrap) is inexpensive and can be sewed up into covers. Try it and you’ll become a believer…
View Elaine's profile
Elaine
113 posts in 3620 days
#5 posted 06-20-2009 03:03 PM
I use wax and old bath towels, when the towels get dirty -shake them out, throw ‘em in the washing machine and voila! I can also sew the towels to fit the machine, sort of like a cover for a grill.
Dick, & Barb Cain
8693 posts in 4297 days
#6 posted 06-20-2009 03:15 PM
I’ve been using WD40, & it doesn’t leave an oily surface.
The wood also seems to slide nicely.
117091 posts in 3574 days
#7 posted 06-20-2009 05:30 PM
Floor wax is inexpensive and works great
YoungManJosh
#8 posted 06-27-2009 01:21 PM
thanks for these tips, i will try to put some to use.
13603 posts in 3338 days
#9 posted 06-27-2009 01:53 PM
rub on ,
rub off .
the zen ,
of tool maintenance !
View Occie gilliam's profile
Occie gilliam
505 posts in 3293 days
#10 posted 06-27-2009 02:28 PM
i use a thin cote of poly on all of my small tools. if you rub it good on flat area with a rag it srays smooth
-- OC down in Costa Rica. come down and see me some time. I'll keep the light on for you too-oc@hotmail.com mail.com
View Moron's profile
Moron
5032 posts in 3891 days
#11 posted 06-27-2009 03:04 PM
avoid “dew point”............you wont need any wax
View juniorjock's profile
juniorjock
1930 posts in 3763 days
#12 posted 06-27-2009 11:37 PM
Even while using the wax, you have to re-apply often. I usually clean the dust off all my machines and start putting a thin coat of the Johnson’s wax on. By the time I’ve applied it to the last machine, the one I did first has dried and is ready to be buffed.
I do have a question though. I’ve heard that if you apply more than one coat of wax, you’re actually just removing the first coat you put on and still end up with only one coat. Is this true?
View kimball's profile
kimball
323 posts in 3294 days
#13 posted 06-30-2009 11:25 PM
Wax appears to be the weapon of choice. I use a scotch brite pad on my random orbit sander with paste wax mixed w/ kerosene to clean rust film . I follow this by a coating of plain paste wax and a good buffing. It has worked well for …....... well….... Ah…..... three years now. Ok, a lot longer.
Good luck, Kimball
