Resawing technique
Forum topic by KellyB posted 03-17-2015 01:01 PM 1003 views 0 times favorited 8 replies Add to Favorites Watch
View KellyB's profile
KellyB
77 posts in 1059 days
03-17-2015 01:01 PM
When resawing on the bandsaw, which face is against the fence: the thinner piece being cut off, or the larger piece?
I have seen it both ways, and wonder which is best.
Thanks.
8 replies so far
View SirIrb's profile
SirIrb
1239 posts in 1107 days
#1 posted 03-17-2015 01:03 PM
I would say thinnest to the fence for accuracy. If you get below 1/8” then flip it to avoid fence damage.
View Scott C.'s profile
Scott C.
158 posts in 1928 days
#2 posted 03-17-2015 01:36 PM
Thinest piece (or rather the veneer your slicing off) towards the fence, so you can make repeated cuts without moving the fence.
-- measure twice, cut once, swear and start over.
View rwe2156's profile
rwe2156
2756 posts in 1357 days
#3 posted 03-17-2015 04:49 PM
You’re all correct!!
I’ve cut veneer against the fence down to 1/16”.
Just for fun I’ve cut it down to just over 1/32” without teeth hitting the fence. :)
If one is worried about hitting the fence u could always line your fence with some UMHW or wood…..
Resawing is one of the most rewarding procedures, isn’t it?
Using bookmatched figured wood for sequential drawer fronts is to me so neat and it conserves a really nice board.
View jmartel's profile
jmartel
7635 posts in 2026 days
#4 posted 03-17-2015 04:54 PM
You re all correct!!
I ve cut veneer against the fence down to 1/16”.
Just for fun I ve cut it down to just over 1/32” without teeth hitting the fence. :)
- rwe2156
That’s what I’ve done. And you would want a taller resaw fence anyway than the stock one. So, just make it out of ply and you don’t have to worry about damaging the teeth.
KellyB
#5 posted 03-17-2015 05:11 PM
Thanks one and all. Pretty conclusive.
Now I’m off to make a proper fence, just proving the Murphy corollary: Whatever you would do, something else must be done first.
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1451 days
#6 posted 03-18-2015 03:03 AM
Now I m off to make a proper fence, just proving the Murphy corollary: Whatever you would do, something else must be done first.
- KellyB
I spend as much time making jigs etc. as I do for the project. sometimes more.
KellyB
#7 posted 03-18-2015 12:06 PM
- KellyB
- daddywoofdawg
I’m glad you said that. Makes me feel much better knowing I’m not the only one.
View JeffP's profile
JeffP
573 posts in 1268 days
#8 posted 03-18-2015 12:18 PM
A rare opportunity to quote two things at once…
Right now I’m spending all of my time in the shop setting up new tools and building shop accessories….so that I can eventually build a jig.
- KellyB
- daddywoofdawg
I m glad you said that. Makes me feel much better knowing I m not the only one.
- KellyB
-- Last week I finally got my $*i# together. Unfortunately, it was in my shop, so I will probably never find it again.
