How do I choose the right speed for my router?
Forum topic by Renfield posted 06-14-2009 01:43 AM 6454 views 0 times favorited 20 replies Add to Favorites Watch
View Renfield's profile
Renfield
8 posts in 3388 days
06-14-2009 01:43 AM
Topic tags/keywords: router variable speed template
I am making curtain hangers for all of the windows in the house. I believe the best way to do this is to make one and use the router and a flush-cutting bit with a bearing to follow the original and make copies.
Each piece is 1 1/2” thick pine. I bought a 2” 3-flute cutter from MLCS. Currently I am finding that the cut is really slow, and seems to also burn the wood. I am running my Makita varible speed router at it’s lowest setting (mostly because it kind of scares me).
I am wondering, what is the right speed to be running my router at for various tasks (and this one in particular)? Are there any hard (or semi-hard) rules like “For this application, and this type of wood, run it at XXX speed”? Or is there some observation I can make to determine the best speed? Also, what are the safety considerations I should be aware of when choosing a speed?
Thanks.
20 replies so far
16276 posts in 4338 days
#1 posted 06-14-2009 02:24 AM
In general, slower speeds are for large-diameter bits like panel-raising bits. (I’m sure someone will bring up some other scenarios where slower speeds are called for.)
For the job you describe, I believe you should be running at full speed. Slow speed is what is causing your problems.
117203 posts in 3696 days
#2 posted 06-14-2009 02:47 AM
I agree with 50/50
View lwllms's profile
lwllms
555 posts in 3401 days
#3 posted 06-14-2009 03:06 AM
I’m not a fan of big router bits in a router. If I were to do it, I’d follow the recommendation of the router bit manufacturer. It’s not that hard to do, digital non-contact tachometers are pretty cheap these days. I’m a little amazed they’re not standard equipment for variable speed routers and other tools. I sure like the one we have.
Amazon’s digital tachs: http://tinyurl.com/m2uerj
Renfield
#4 posted 06-14-2009 03:36 AM
This bit didn’t come with speed recommendations from the manufacturer. I bought the 2” flush trim bit here:
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/triplewing.html
View cabinetmaster's profile
cabinetmaster
10874 posts in 3678 days
#5 posted 06-14-2009 03:51 AM
I’ll try to find my speed chart. But the rule of thumb is the smaller the bit, the higher the rpm on the router. 2” or larger bits should only be used at the slowest rpm and take no more than 1/16 to 3/32” off the wood at one time. MY QUESTION TO YOU: how much wood are you trying to take out at one time? Are you cutting these patterns out with a bandsaw or jigsaw close to the line and then using the flush trim to bring it down to the pattern? Or are you trying to hog it all out at one time? Really makes a difference and makes the router bit last longer if you do cut it down to size before using the flush trim bit.
View Kjuly's profile
Kjuly
308 posts in 3405 days
#6 posted 06-14-2009 04:01 AM
Hi Renfield,
As Charlie said you are running too slow for the bit that you are using. Most router bit manufacturers publish a guide for router speeds.
As a rule of thumb…you do not need to reduce the router RPMS until the bit diameter exceeds 1”. I found the chart below from a quick internet search. This illustrates the rule except the last line which should be no more than 10,000 rpms for a bit that size.
Maximum Speed (RPM)
Up to 1” 24,000
1 1/4” to 2” 18,000
2 1/4” to 2 1/2” 16,000
3” to 3 1/2” 12,000
Bit Speed chart courtesy
Infinity Cutting Tools
Visit www.infinitytools.com
The more flutes the slower the cutting speed but the better the finish.
I suggest you make a patten and go from there.
By using a pattern you can rough cut your parts about an 1/8” oversize with a bandsaw or scroll saw and then finish cutting the part with the router.
This method will be easier on you and your router.
I hope this helps.
Keith
-- Keith, Charlotte, MI www.julyswoodworks.com
TopamaxSurvivor
18358 posts in 3795 days
#7 posted 06-14-2009 08:48 AM
My guess is taking too much material and / or trying to go too fast along with possible speed problems. Wood doesn’t disipate heat like metal does; therefore, smaller bits and less pressure.
13625 posts in 3460 days
#8 posted 06-14-2009 09:25 AM
i think you are saying that the bit cutting length is 2 inches ?
i imagine the diamiter is 1/2 or 3/4 ?
so as stated above high speed !
also are you routing by hand ( in which case the work must be solid and no obsructions around edges ) .
or are you using a router table ?
as stated cut all pieces close first , but try and make your pattern of some hard and smooth material ,
as it will have a tendency to crush and burn or splinter over long use .
remember that as the grain direction changes you have to be in control and not let the work bounce around or you can have it chatter and break .
View BigJimAK's profile
BigJimAK
30 posts in 3410 days
#9 posted 06-14-2009 10:42 AM
Rockler’s recommendations for MAXIMUM speed are:
Router Bit Diameter Maximum Speed
Up to 1” 22,000 – 24,000 rpm
1” to 2” 18,000 – 22,000 rpm
2” to 2-1/2” 12,000 – 16,000 rpm
2-1/2” to 3-1/2” 8,000 – 12,000 rpm
You can see the post yourself at:
http://www.rockler.com/articles/display_article.cfm?story_id=135
Please note that they indicate these as guidelines, to be used only if manufactuer information is not available. From this chart, i’d say a MAX of 16,000-18,000 rpms.
If it were me with that large of a bit, I’d check to ensure the bit was clean and sharp and then slow it way down. Burning comes from moving the bit too slowly through the wood or a dull/dirty bit. If you are nervous about running that large of a bit (and it is a big one), you may be feeding the router too slowly or taking to deep of a cut in each pass.
Consider these things but don’t do anything you’re uncomfortable with. If it feels dangerous, it probably is.
With a bit that large, you’d be better off in a router table, if possible. I try to limit myself to a 1” bit for hand routing.
Jim
-- Jim in Alaska
Renfield
#10 posted 06-14-2009 12:31 PM
Thanks for all of the responses. First some clarifications. The bit’s diameter is 1/2”. The bit is 2” tall. This is so that I can cut the shape out of 1 1/2” thick pine. Also I am cutting close to my pattern line using my bandsaw. I would say that I have 1/8” to 3/16” of wood left that needs to be removed to match the pattern. I have my router mounted in a table, and I am moving the wood across the bit freehand (right to left against the direction of cut of course).
I like the other idea that the pattern should be made of hard material. My pattern is just another block of pine that I made by hand in the bandsaw and sanded to the final shape. This was the prototype piece.
I am using some carpet tape to keep the pattern connected to the piece to route. I had some other double-sided tape but it just didn’t hold.
View doyoulikegumwood's profile
doyoulikegumwood
384 posts in 4112 days
#11 posted 06-14-2009 01:04 PM
doing this free hand i sure hope you have a starting pin if your geting burning i hate to say it but your bit mite be eather dull or dirty i would try cleaning it sharpaning a pattern bit i have found is not cost effective because after sharping the bit the baring and the carbid no longer match but i digress a little burning is to be expected. a little sanding takes care of this. also burning is a little more noticeable if your useing a 1/4 in shank bit. dont know if i was any help but good luck to you
-- I buy tools so i can make more money,so ican buy more tools so I can work more, to make more money, so I can buy more tool, so I can work more
#12 posted 06-14-2009 03:23 PM
Again, after reading all the clarification, it sounds like you are doing everyting right except bit speed. Turn it up to full and I’ll bet your problems disappear.
cabinetmaster
#13 posted 06-14-2009 03:47 PM
50/50 is right.
Renfield
#14 posted 06-15-2009 09:41 PM
Ok, I have increased the router speed from 8,000 RPM to 24,000 RPM. The wood still burns, unfortunately. I am able to cut much faster though. This is a brand new bit that I just bought from MLCS, so I can’t believe it is dull. I am guessing that the problem might be that I am trying to cut through too much wood. Realize that the piece I am trying to make is 1 1/2” thick. This seems to be much thicker than any examples I have seen.
My next attempt will be to cut much closer to the pattern line on the band saw first. Also I will make the pattern out of some plywood instead of using the pine prototype. I will have to create a zero clearance throat plate for my band saw, since I will want to go slow and take off small amounts of wood in each pass, and I do not want the wood to fall into the machine.
Further, I do not have a router starting/safety guide pin. I understand now the usefulness of this, and will attempt to fashion one.
#15 posted 06-15-2009 10:17 PM
Is the burning consistent, or just in spots?
Burning is usually caused by too slow of a feed rate. If you are just getting marks at certain points, those are probably the points where you are stopping or slowing the feed of material to adjust your grip, etc.
It can be very tricky to maintain a constant feed rate, but leaving the bit in one place will almost always leave a burn mark.
