Dust Collector Canister Filter, WARNING!! Shake your canister pleats often.
Forum topic by Dick, & Barb Cain posted 162 days ago 448 views 0 times favorited 8 replies Add to Favorites Watch
Dick, & Barb Cain
7034 posts in 1192 days
162 days ago
Topic tags/keywords: tip dust collector dick
I fixed my problem today, so check my latest Blog.
I had my shop became a sawdust hazard the other day.
I was doing a lot of sawing, and all of a sudden, it was snowing sawdust in my shop.
I looked up at my dust collector, & the cover of the canister had popped loose,
& that’s what caused the sawdust storm.
The canister has a lever that controls a flapper that shakes the pleats for clearing them.
When I purchased the canister, it didn’t say how often to shake it clean.
I guess I’m going to do it more often from now on.
I glued the cover back on with polyurethane glue.
I’m also trying an experiment, by putting a deflector vane on the bottom of the canister.
Because there were a lot of larger sized chips that that got caught in the pleats.
I’ll let you know how this works after using it for awhile.
After cleaning the filter the DC works much better now.
With a 1 micron filter I think it will also plug up much quicker.
There seems to be more action going on in the collector bag now.
Here’s a picture of what I did.
25797 posts in 1293 days
162 days ago
Dick: i thought mine sayed to shake it every day. GaryK also made a statement to that same fact about 1 yr ago is I remember correctly.
Dick, & Barb Cain
162 days ago
I have to get up on a ladder to do it, so it takes a little more effort, & I must not have read the directions, as usual!!!
View MedicKen's profile
MedicKen
457 posts in 355 days
162 days ago
Dick….Is there a way that you can extend the handle on flapper so you dont have to climb to operate it?
162 days ago
Dick when I converted mine from a bag system to a canister this is the handle arrangement that came with my setup.
You might be able to do something like that with some wood and a broom handle.
View hairy's profile
hairy
293 posts in 425 days
162 days ago
It hasn’t happened to me yet, but it did to my brother. He had the same advice – make it a habit to rotate the flapper everyday. All the air that gets sucked in a dust collector has to get out. It goes out through the filter. The flapper keeps the filter open on the inside by knocking the dust off the filter, so it can fall into the bag.
-- I'm a lumberjock and I'm ok, I sleep all night and I work all day!
View snowdog's profile
snowdog
808 posts in 875 days
161 days ago
Never happened to me either but once I forgot to turn the flappers for a few weeks and it took some work to loosen them up so they would move freely again.
Dick, & Barb Cain
161 days ago
I’m presently jerry-rigging a cranking mechanism, so I won’t have to climb a ladder.
It is 9 feet from the floor. I never had to worry about it that high up with the filter bag.
I’ll post it when it is done.
Dick, & Barb Cain
161 days ago
I fixed my problem today, so check what I did in my Blog.
