Calling All Akeda Dovetail Jig Owners
Forum topic by pintodeluxe posted 03-16-2015 10:37 PM 1422 views 0 times favorited 8 replies Add to Favorites Watch
View pintodeluxe's profile
pintodeluxe
5623 posts in 2781 days
03-16-2015 10:37 PM
Topic tags/keywords: akeda dovetail jig akeda dovetail jig
I have used a PC 4200 dovetail jig for some time now with good results. It does pretty much everything I need it to for half blind dovetail drawers. Now I need a jig that will do variably spaced through dovetails. The Akeda looks like a nice option. I read that the stock thickness is limited to 3/4”. While most of my dovetail work will be on stock 3/4” or thinner, it would be nice to make boxes and cases that are 1” thick.
My question is this: Have any of you Akeda jig users found a way around this 3/4” stock thickness limitation?
Thanks in advance for any help you can offer.
8 replies so far
View ElChe's profile
ElChe
630 posts in 1305 days
#1 posted 03-17-2015 12:37 AM
The Akeda works with 1” thick boards. I use the 6 degree pin fingers. I’ve only done a small box that was 1” thick but it worked.
pintodeluxe
#2 posted 03-17-2015 04:39 AM
Thanks Tom. Was that a through dovetail? The jig looks like it will fit 1” stock, but is there a dovetail cutter long enough to do 1” through dovetails?
Thanks again.
pintodeluxe
#3 posted 03-17-2015 08:32 PM
bump
ElChe
#4 posted 03-17-2015 11:05 PM
Hi Willie I checked the box and I used 7/8” thick wood not 1”. I can’t recall if I was at its capacity or not. Through dovetails. Sorry I can’t be more helpful. Tom
pintodeluxe
#5 posted 03-17-2015 11:32 PM
Great, thanks again Tom.
View thiel's profile
thiel
387 posts in 3260 days
#6 posted 03-30-2015 03:38 AM
The Akeda documentation is clear: up to 1” dovetails are possible. You will certainly be close to running out of carbide on your router bits at that size, but with a plunger and two passes (recommended anyway) it’s not a problem.
Akeda’s service level is the tops. Once you get the hang of the jig, it’s unbelievable simple and expedient to use. Safe too.
-- Laziness minus Apathy equals Efficiency
thiel
#7 posted 03-30-2015 04:18 AM
BTW… I have one, so I can confirm that the documentation is correct and 1” dovetails work just fine. You can even one pass them if you really want..
pintodeluxe
#8 posted 03-30-2015 03:24 PM
Thanks, that’s good to know.
I’m still looking for one if anyone has a jig for sale.
