Bandsaw repair in Albuquerque?
Forum topic by Dave66 posted 03-16-2015 03:31 PM 910 views 0 times favorited 7 replies Add to Favorites Watch
View Dave66's profile
Dave66
17 posts in 2090 days
03-16-2015 03:31 PM
Topic tags/keywords: repair service bandsaw tools question
I am new to bandsaws. This one is the first I’ve ever had.
It’s a Grizzly G0513X2BF, 17-inch saw. I’ve been using it for light work for about a year. It’s had two blades on it: a 1/8-inch, 14-tpi regular tooth and a 3/16-inch, 10 tpi regular tooth. Light duty use no really thick pieces or hard woods. The 1/8 inch blade broke after several months. Installing the 3/16 – blade was a challenge to get it to track. But, it finally did.
Then I wanted to switch to a 3/16-inch, 4 tpi skip tooth. I can not get it to track to save my life. I replaced the tires and the blade still won’t track. it seems to track when turning the wheel by hand, but as soon as the motor spins up, the blade jumps off the wheel.
I know I should check for coplanarity, but I’ve never done that before, and I’d like to be back in operation quickly so my grand daughter and I can finish a project before she has to go home. Also, isn’t it a little early for a 1-year old saw to need coplanar adjustment?
Is there anyone in the Albuquerque area that could help?
Thanks
7 replies so far
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1570 days
#1 posted 03-16-2015 07:32 PM
check your tension,and On mine the upper wheel is attached to a bracket with a upside down U that hangs over a post,I couldn’t see that till I played with it;but I couldn’t get it to track right either till I saw that,and made sure it was on right and then I could tension the blade and the tracking was fine. I.E check to make sure the wheels are set like they should.The co-plane shouldn’t go out once you have them working right.The gullet of the blade should be in the center of the wheel.and any gauge on the saw for tension ignore.and tighten by feel less than 1/8” left or right flex.
MrUnix
6703 posts in 2194 days
#2 posted 03-16-2015 07:48 PM
The wheels don’t need to be co-planer. Switch back to the blade that worked and finish your project, then you will have time to figure out what is really the problem with the new blade.
View gfadvm's profile
gfadvm
14940 posts in 2685 days
#3 posted 03-17-2015 01:00 AM
On those narrow blades you need to decrease the tension and track them where the bottom of the gullets are centered on the wheel. Then adjust your guides and you should be good. Overtensioning narrow blades is a common mistake (I’ve been guilty).
Dave66
#4 posted 03-17-2015 02:06 AM
Thank you, everyone.
Over tension? All of the literature, including the saw manual says failure to track could be under tension. Anyway, I got the new 4 tpi skip tooth blade to track, somehow. It worked great for about half an hour, then the blade broke.
Over-tension? Could be. It was a little tighter than the 1/8 – inch blade, but still deflected about 1/4 of an inch. Could it have been a bad blade? Kink? After it broke, it relaxed into about four different kinks. Doesn’t matter, I’ll try again.
gfadvm
#5 posted 03-17-2015 02:15 AM
If your blade broke at the weld, it was a defective blade (I would return it). Timberwolf will replace blades that break at the weld (or at least they have in the past, haven’t broken a blade for a LONG time). Did it get kinked when it came off the wheels?
Dave66
#6 posted 03-17-2015 02:39 AM
Yes, it looks like it broke at the weld. And, there were three very obvious kinks when it came off the wheels.
Dave66
#7 posted 03-20-2015 05:22 PM
A gentleman named Mark Nowicki on another service sent me this link : https://www.youtube.com/watch?v=wGbZqWac0jU
I followed the instructions there and had a new blade installed tensioned and tracking in minutes.
