How make straight cuts w/out jointer/planer?
Forum topic by SmellTheWood posted 03-16-2015 02:43 PM 1198 views 0 times favorited 10 replies Add to Favorites Watch
View SmellTheWood's profile
SmellTheWood
1 post in 1137 days
03-16-2015 02:43 PM
I’m building a shaker column out of MDF and I’m trying to figure how to make straight, even cuts on 75” stiles without jointer or planer. I’ve already cut them with my table saw but they’re not perfectly even. Suggestions/experiences would be greatly appreciated.
I only have contractor saw table, router, random-orbit sander, and some hand tools to work with. I can post my progress if anyone is interested.
Many thanks.
10 replies so far
View HornedWoodwork's profile
HornedWoodwork
222 posts in 1183 days
#1 posted 03-16-2015 03:08 PM
I assume your cuts aren’t straight because the edge riding your TS fence isn’t straight. A simple method would be to apply a straightedge to the MDF and run your router along this straightedge with a trim bit. You could use double sided tape or simply clamp it to the MDF (Watchout for sag in the middle of the cut, at 75” there will be plenty of sag in the middle if you simply clamp the ends). Another method would be to apply a straightedge to the MDF and run the straightedge against the fence of the saw. This will establish the cut edge as straight, then you can run the cut edge against the fence and you should have parallel edges assuming the TS is setup well.
-- Talent, brilliance, and humility are my virtues.
View MrUnix's profile
MrUnix
6609 posts in 2168 days
#2 posted 03-16-2015 03:12 PM
How could the factory edge of the MDF not be straight? Sounds like you need to tune-up your table saw. If you are using already cut MDF which isn’t straight, the above suggestion would work, or use the straight edge and a circular saw to clean it up. Lots of ways, and a jointer/planer is not always required.
View bonesbr549's profile
bonesbr549
1531 posts in 3036 days
#3 posted 03-16-2015 03:14 PM
This is one way. Just use a factory edge from your mdf or a piece of ply and leave the pieces long and use a screw to attach, or use carpet tape.
https://youtu.be/dCKFhjB5Wk8
View InstantSiv's profile
InstantSiv
262 posts in 1564 days
#4 posted 03-16-2015 03:15 PM
I would say to buy a cheap piece of ply and make a diy track saw for your router.
Rough cut the pieces on the table saw and use the track saw w/ router to the final dimensions.
OR
Get the factory edge of a piece of ply and make an extended length fence for your table saw. That will make it easier to get a straight cut the length of the rip.
runswithscissors
2725 posts in 1994 days
#5 posted 03-20-2015 06:47 AM
MDF? I wouldn’t run it through a jointer or a planer.
View dhazelton's profile
dhazelton
2756 posts in 2265 days
#6 posted 03-20-2015 01:29 PM
I’d make the rails and stiles out of real wood, not MDF. And yeah – I wouldn’t try to joint it either.
View MT_Stringer's profile
MT_Stringer
3160 posts in 3200 days
#7 posted 03-20-2015 02:42 PM
I don’t know what a shaker column is. Post a picture of what you are attempting to make.
Are you saying you have ripped the pieces to length and they are not the same width when you stack them on edge? I am not sure what would cause that – dull blade, short fence maybe.
One option would be to make an auxillary fence that is longer, say 40 inches or thereabouts. Attach it to the table saw fence. Then when you rip longer boards, they will follow the fence and help eliminate any wayward moment. Regardless, the distance from the blade to the fence should remain constant when the cutting is taking place.
Good luck.
Mike
View Ghidrah's profile
Ghidrah
667 posts in 1191 days
#8 posted 03-20-2015 05:57 PM
Shaker columns are square instead of round, apparently they can also be tapered. Some pics I’ve seen also have corner trim. I’d consider using MDO over MDF whether its for outside or not, it’ll make painting easier too.
-- I meant to do that!
View mrg's profile
mrg
820 posts in 2968 days
#9 posted 03-20-2015 07:08 PM
Thats a long rip. Are you sure your not walking away from the fence, or that the fence is deflecting. If the parts are wider as your cutting them you may have knocked the fence out of alignment.
-- mrg
View devann's profile
devann
2246 posts in 2661 days
#10 posted 03-20-2015 10:57 PM
How wide are you stiles? I’ve learned that cutting some sheet stock into thin rips sometimes ends up with a slight bow. I believe it is because of the glue and the heat generated by the cutting action. I’ve learned that when ripping osb 6” and smaller I end up with a curved rip. I’ve seen mdf do the same when I was ripping it into 1 1/2”,2” rips for doubling thickness at counter top edges. Plywood seems to be more stable.
