| Forum topic by Rob Drown | posted 166 days ago | 524 views | 0 times favorited | 11 replies | ![]() |
166 days ago |
Topic tags/keywords: tablesaw question milling If your SawStop break has tripped and it didn’t touch your finger, Please share what did trip it. I trripped mine with a carpenters pencil lead. I had turned the saw off, it was coasting and I was using a pencil to move small pieces of maple away from the blade. POW. Fastest $200 i ever spent. Hopefully we can help each other avoid the expense. If your finger has been saved please share that also. Thanks. Rob -- Sharp tools and thin whispy shavings make woodworking a joy. |
166 days ago |
good post – very informative. I think it’s a good idea to keep track of this cause. -- When in doubt - There is no doubt - Go the safer route. |
166 days ago |
I agree with Sharon. You might want to forward that info to SawStop. I would think they could add a section to their manual (or web site) to alert folks of what can cause an accidental trip. |
166 days ago |
If it was your finger $200 would seem like a bargain -- Jim from Heirloom Woodshop Southern Oregon |
166 days ago |
I don’t know anything about Saw Stop, but it probably works on the electrical capacitance of the blade. They are probably using very sensitive electronic to sense any change. -- Debt is nothing more than the 21st Century's form of slavery. |
166 days ago |
I’ve heard a small brad or even wet glue in a fresh joint will stop it cold. The local plastic shop has one and they found out that foil backed plastic sheet sets it off. It has bypass mode for cutting wet wood or anything else known to be conductive but that bypasses the safety also. -- Sharp tools and thin whispy shavings make woodworking a joy. |
166 days ago |
That’s indeed how it works, TopamaxSurvivor and yes, they have instructions on how to disable the system in order to cut green wood or other conductive materials. -- Jojo, shopless in Kyoto ยท http://twitter.com/kagushokunin |
165 days ago |
I work at the Marc Adams School of Woodworking and we have 8 SawStops in the building. In the 2 1/2 years we’ve had them the brake pad has been tripped by brads, wet glue. Also riving knife we forgot to take out when we cutting a new throat plate; in raising the blade through the plate the knife got pushed down and just touched the blade. A couple brake pads went off on their own. Supposedly there is “black box” in the brake pad that SawStop can examine. I believe that in that manual is mentions that the brake will activate as long as the blade is spinning (even after you push the stop switch.) We’ve not had any finger incidents since we use the “3inch / 12 inch rule” for our machinery. The 12 inch rule means that if your stock in less than 12” long, you need to consider whether a piece of machinery is appropriate for the operation you want. Stock under that length needs attached to a bigger piece of wood or the use of a jig, etc that makes the small piece behave like a bigger piece of wood. |
165 days ago |
I was pushing my cutoffs out of the way with a hot dog until I tripped the darn thing. Won’t do that again. -- Just 'cause a cat has kittens in the oven, it don't make 'em biscuits. |
165 days ago |
Bwahahahahahaha! -- //FC - Round Rock, TX - "Experience is what you get just after you need it" |
163 days ago |
A screw tripped mine. -- Robert in middle TN |
162 days ago |
I wonder if this is going to be like Ground Fault Circuit Interrupters (GFCI) when they first came out and were required on all construction sites? So many nuisance trips nobody could get any work done. -- Debt is nothing more than the 21st Century's form of slavery. |
| Forum | Topics |
Woodworking Skill Share
2909 |
3934 |
256 |
946 |
223 |
Woodworking Trade & Swap
617 |
Coffee Lounge
2378 |
LumberJocks.com Site Feedback
522 |
