Play "Name That Tool!"
Forum topic by Glenn posted 06-11-2009 04:47 PM 1216 views 0 times favorited 10 replies Add to Favorites Watch
View Glenn's profile
141 posts in 3317 days
06-11-2009 04:47 PM
Topic tags/keywords: question
I admit to buying cheap, Asian-made tools wherever possible. Problem is the manuals are often factually-erroneous, grammatically incorrect, or downright incomplete. Below are two parts left over after assembly of two power tools, and I’m hoping someone can identify them and/or tell me their purpose. The fork is shown for reference. The first:
is from a Ryobi drill press. The manual lists it as a “chuck tool” in the diagram of loose parts, but I can’t find any further reference to its purpose. Any ideas?
The second tool is from a 6” Harbor Freight jointer:
I can’t find this thing listed anywhere in the manual. Has anyone seen anything like this before? I assume it has something to do with the cutterhead…
-- Glenn, Arkansas
10 replies so far
View PurpLev's profile
8534 posts in 3579 days
#1 posted 06-11-2009 04:58 PM
I think the fork is used for eating purposes…. I’ve seen it in some restaurants.
The first part “chuck tool” ?!? maybe you chuck it in the tool ? I cant really tell. lol
but the 2nd part looks like it’s used to set the blades in the cutterhead. kind of a handle to hold the blade as you put it in and lock it. would that make sense?
13598 posts in 3271 days
#2 posted 06-11-2009 05:01 PM
the first is a chuck remover , or quill remover ,
put it in slot over chuck and tap with hammer to remove chuck from spindle .
the second is a knife setting stop , when you put knives back in machine use it to adjust the knifes
to same hieght , ( they are washboard close , as the knifes tend to drift when you tighten lugs , do so evenly ,
kind of like tightening lug nuts on a tire , little by little on each one ) .
View bayspt's profile
292 posts in 3635 days
#3 posted 06-11-2009 05:04 PM
I am assuming you have a DP with a morise taper lock chuck. This “tool” (or a screw driver or other instrument) is inserted in the slot in the spindel and used to “pry” the chuck out of the morise taper.
Move the spindel down and you should see the “slot”. on the other I guess I’m with PurpLev since I have no clue.
-- Jimmy, Oklahoma "It's a dog-eat-dog world, and I'm wearing milkbone underwear!"
#4 posted 06-11-2009 06:05 PM
Both of those procedures sound very scary. I think I’ll put them off for as long as possible. Thanks for the advice…
-- Glenn, Arkansas
View Don Newton's profile
Don Newton
714 posts in 3549 days
#5 posted 06-11-2009 06:18 PM
Hey Glenn,
How about a review of the tools once you get them up and running? I’m sure there are other Lumberjocks who don’t use a particular tool that ofen and would entertain buying a less expensive version. We all know that Powermatic and Sawstop make good tools.
-- Don, Pittsburgh
View rtb's profile
1101 posts in 3643 days
#6 posted 06-11-2009 06:23 PM
Actually removing the chuck is just as simple as it sounds as the chuck is just held in place by pressure.
-- RTB. stray animals are just looking for love
#7 posted 06-11-2009 06:27 PM
Yea the chuck is easy, setting Jointer knives however, is a exercise in paitence.
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3216 days
#8 posted 06-11-2009 07:27 PM
Setting jointer knives can also be a test of your religion!!!!!!!!!
View FEDSAWDAVE's profile
293 posts in 3362 days
#9 posted 06-12-2009 01:10 AM
You won’t need to worry about removing any chucks. The Chinese crap will eventually just fall off…
-- David,
View AdamThorpe's profile
13 posts in 3221 days
#10 posted 06-26-2009 12:45 AM
the actual name of the first tool is called a drift
