Sharpening Lathe Tools
Forum topic by Kevin posted 172 days ago 561 views 0 times favorited 9 replies Add to Favorites Watch
Rockler
View Kevin's profile
Kevin
25 posts in 231 days
172 days ago
I just bought a new mini lathe for pen turning and am trying to find out what i need to sharpen my tools. Basically i know a slow speed grinder and that’s about it. If you could help me i would really appreciate it thanks.
View Roper's profile
Roper
762 posts in 613 days
172 days ago
a gringer and a solid platform are all you need.
-- Roper - Master of sawdust-
View LesB's profile
LesB
555 posts in 343 days
172 days ago
For my part I get by with a regular bench grinder (1750 rpm) using white or pink wheels and being careful not to let the heat build up. Once you get the and shape you want all it takes is a quick touch up when you notice the tool is not cutting well.
Next, it is nice to have the tool holders, especially for sharpening gouges. There are several good commercial ones and I have seen several home made ones. With practice and experience you can do it free hand but you may grind away a lot of tool metal learning. I do most of my pen work with a small gouge to round up the stock and a round nose scraper for the final shape and finish….plus sanding. It could also be done with a skew but that too takes some practice to learn how to use it well.
-- Les B, Oregon
View Matt's profile
Matt
178 posts in 272 days
171 days ago
Woodcraft is always selling their chinese ‘slow speed grinder’ for a good price. Add a Wolverine jig or look at one and build your own. That should just about do it. Get a black marker while you’re learning. Color the bevel so you can easily see what is being ground off of your tool. If the steel turns blue, let it cool off and start over.
-- Matt - My Websites - http://www.bestinwood.com - Hand Tools :: http://www.workshopgarage.com - Small Shops
View Chris Wright's profile
Chris Wright
360 posts in 381 days
168 days ago
Well, I’d say it comes down to the types of turning tools you have. I’ve found that using a bench grinder on my mini detail tools is like using a sledge hammer to drive a tack. I have a “low” speed grinder with the Oneway Wolverine sharpening system. That works great for my full size tools. I grind the the edges and then touch it up with a diamond hone while I’m turning. For my mini tools, I will free hand touch them using the Tormek water cooled grinder I have and again, use the diamond hone to get the final edge. Now, I know that both these systems are rather pricey, especially for a new comer to the trade, so if you have access to a regular bench grinder and use a gentle touch so you don’t burn the steel and then touch the edge up with a honing stone, you will get some good results.
-- "At its best, life is completely unpredictable." - Christopher Walken
View trifern's profile
trifern
7896 posts in 667 days
168 days ago
I use a slow speed grinder and the Wolverine sharpening system.
View Dusty56's profile
Dusty56
3518 posts in 588 days
163 days ago
A typical “slow-speed” grinder is 1725rpm . I’m not sure what LesB is referring to as a “regular bench grinder” because your average “regular” grinder runs at 3450rpm.
I recently purchased the Worksharp system and it is very nice and does a great job without overheating your tools , plus there is no water involved .
View Jim's profile
Jim
67 posts in 898 days
162 days ago
I use a regular grinder and a psi sharpening system (basically a wolverine) and a worksharp 3000
-- Jim in Cushing Oklahoma
View cabinetmaster's profile
cabinetmaster
8749 posts in 458 days
162 days ago
I used a regular shop grinder, then I went to a slow speed wet grinder. Now I have the Worksharp WS-3000 and let me tell you it does a fantastic job. I have my chisels sharper now then I ever had. Would highly recommend this worksharp for $199 at most places that sell them.
View PatentNonsense's profile
PatentNonsense
27 posts in 266 days
161 days ago
LOTS of good discussion of this topic in the AAW forums – see aawforum.org, and/or go to their annual meeting next weekend in Albuquerque if you can.
