What size biscuit to use?
Forum topic by EFA posted 06-11-2009 04:38 AM 1978 views 0 times favorited 5 replies Add to Favorites Watch
View EFA's profile
EFA
6 posts in 3311 days
06-11-2009 04:38 AM
I’m working with 5/8” baltic birch and have a several T-joints. Should I use #10 or #20 biscuits?
Thank you,
5 replies so far
View LesB's profile
LesB
1548 posts in 3346 days
#1 posted 06-11-2009 08:24 AM
You didn’t say but I will assume you are working with a face frame??
Biscuits won’t add much in the way of strength if that is why you are using them and the smaller size will help even less. They are best for keeping things aligned as you glue them up.
If they won’t show I would use Kreg pocket holes and screws to hold it together. Even if they are visible you can plug the holes.
If you can’t use the screws and still want to strengthen the joint consider dowels inserts or there are other joints you can make, such as lap joints, and mortise and tenon.
-- Les B, Oregon
View longgone's profile
longgone
5688 posts in 3212 days
#2 posted 06-11-2009 07:53 PM
I would use the #10’s. The 20’s might be a little deep for the 5/8 if you are butt joining them.
View Moron's profile
Moron
5032 posts in 3797 days
#3 posted 06-11-2009 08:15 PM
2 cents
I politely and respectfully dissagree with LesB but not to say that there arent stronger joinery techniques out there
10s or 20s will work
View LesB's profile
LesB
#4 posted 06-11-2009 08:48 PM
4 cents
There have been several test done by various magazine on joinery and the conclusions were pretty unanimous that biscuits add very little strength to the glue joint but then again if it is glued properly the bonds are usually stronger than the wood it self. For face frames it probably makes little difference because the glue bond to the case reinforces the face frame joints. Kreg screws is still the best in my opinion and allow for faster assembly with no clamping.
-- Les B, Oregon
View GaryK's profile
GaryK
10262 posts in 3891 days
#5 posted 06-11-2009 09:36 PM
I always use the largest I can get away with.
