Resawing with the bandsaw issues
Forum topic by daddywoofdawg posted 03-14-2015 05:09 PM 1092 views 0 times favorited 11 replies Add to Favorites Watch
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1568 days
03-14-2015 05:09 PM
Topic tags/keywords: bandsaw question
I have a 10” craftsman bandsaw I know it’s not the best, but it’s better than some,I have followed the you tube (forget his name) bandsaw clinic,and double checked with a couple other posters,and believe my saw is tuned up right;Now here is the problem, when I’m making band saw boxes, I’m cutting a 3.5×3.5” oak block it cuts power wise fine but I’ll get about 2” into the cut and the blade starts starts to wander all over and I can’t keep a straight line.Is it the wood I’m cutting is to much for the blade,the blade it’s the stock 3/8” one it came with (ya waiting on a wood-mizer or timber),or do I have my set-up wrong(need more blade tension, bearings set different etc)?
11 replies so far
View jmartel's profile
jmartel
7877 posts in 2143 days
#1 posted 03-14-2015 05:20 PM
Dull blade or incorrect tension. Buy a new good quality blade for it and try it out. Most stock blades are pretty awful.
View lndfilwiz's profile
lndfilwiz
104 posts in 1594 days
#2 posted 03-14-2015 05:25 PM
I have a craftsman 12” and found that I had to go with a 3 tpi blade for resaw. I also found that zi went to a ½” wide blade it would stay into the cut longer. The stock blade overheats and loosen up.
-- Smile, it makes people wander what you are up to.
View jsuede's profile
jsuede
69 posts in 1217 days
#3 posted 03-14-2015 05:34 PM
Jmartel is prolly right on the button. I personally struggled with feed rate when I first started resawing on my 15” grizzly with the stock blade, seemed to hawg through with power to spare, but would begin to wander quickly. When I slowed to a snails pace it calmed down considerably. Widest, sharpest, lowest TPI blade solved any issues I had permanently.
View ElChe's profile
ElChe
630 posts in 1330 days
#4 posted 03-14-2015 05:37 PM
+1 on blade being dull. Or not the correct teeth per inch. Stock blades tend to be poor quality and more general purpose higher tpi for contour type cuts.
daddywoofdawg
#5 posted 03-14-2015 06:06 PM
ok so I need a new blade, I think I can go to 1/2”, so I’ll open a can of worms, wood-mizer or timber or olsen? budget is a issue and I don’t do production work.
jmartel
#6 posted 03-14-2015 06:09 PM
On a 10” saw you may or may not be able to do 1/2” blades. I’d double check that first. And not necessarily what the manufacturer recommends. According to Grizzly, my 14” saw can handle 3/4” blades, but in reality that doesn’t work.
So maybe buy a 3/8” blade with as low of a tooth count as you can.
I didn’t like my Olsen as much as my Woodslicer that I have on now.
View Jim Finn's profile
Jim Finn
2656 posts in 2915 days
#7 posted 03-14-2015 10:27 PM
get a Supercut carbide blade, 1/2” Inexpensive and very sharp and stay that way a long time.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1170 days
#8 posted 03-14-2015 10:31 PM
Another worm for the “can” would be the timber wolf line of blades. I have always had good luck with them.
View SuperCubber's profile
SuperCubber
1025 posts in 2278 days
#9 posted 03-15-2015 03:26 AM
I have that saw, and you can definitely resaw on it. I tried the same thing you are trying when I first got it.
I will gladly swear by TimberWolf. I bought a 1/2” and a 1/4” to make an oak bandsaw box. Sliced through it like butter. Specifically, I bought a Timber Wolf 1/4” x 6PC and a Timber Wolf 1/2” x 3PC. I even did some resawing with the 1/2” and it exceeded my expectations. Easy to get a straight line and very little cleanup required. Total price (for both), including tax and shipping was $39.63.
Hope that helps!
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
View rwe2156's profile
rwe2156
2916 posts in 1474 days
#10 posted 03-15-2015 01:35 PM
You’ve either got the wrong blade for resawing or its not tensioned enough.
I’ve done my share of resawing and here’s what I’ve found:
1. The right blade. No more than 4 TPI staggered hook pattern. Get a 1/2” resaw blade from Highland Hardware. I think its called a woodmizer. If you don’t have the right blade the sawdust builds up and ruins the cut. I have an 18” bandsaw that will take up to 1 1/4” blades, but I’ve found a 1/2” resaw blade is quite sweet.
2. Tension. Don’t go by gauge on saw. Put blade guide all the way up and tension until less than 1/8” deflection sideways.
3. The type of wood and feed rate also are factors, although minor in a properly set up machine.
IMHO resawing on a 10” machine will be a challenge. If you’re resawing stock less than 4” I would consider using a table saw.
View sawdust703's profile
sawdust703
270 posts in 1413 days
#11 posted 03-16-2015 12:27 AM
My suggestion as well, 2156. I’ve made numerous attempts to re saw on my 10” band saw, & regardless of who’s utube video I watch, or what method I’ve used to set it up, its by far faster, easier, & more efficient for me to get the job done on my ts. Now, granted, my ts is just an 8” post Civil War Craftsman. But, it does all I expect of it, & then some, but I respect its limitations. Without guards & all that fancy dust removal junk on it. And, I might add, I still have all my fingers. I cut my stock to the width & thickness I need on the ts, as long as its w/in its limitations. Otherwise, I just have to make adjustments as needed. Enjoy the day.
-- Sawdust703
