Looking for a marking tool with unique specs.
Forum topic by InstantSiv posted 03-14-2015 03:01 AM 817 views 0 times favorited 4 replies Add to Favorites Watch
View InstantSiv's profile
InstantSiv
262 posts in 1562 days
03-14-2015 03:01 AM
Topic tags/keywords: jig question
I have a part that needs pocket holes. What I do is gang them all up and mark the pocket hole locations all at once. I’m trying to figure out a jig where I can just push the piece into the jig and it’ll mark the locations. Question is what’s a marking tool I can use that doesn’t dull and need sharpening like a pencil, dry out like a sharpie,.. Ideally a no maintenance marker.
View Ripthorn's profile
Ripthorn
1454 posts in 2952 days
#1 posted 03-14-2015 03:08 AM
Any marking device will wear. Pictures would help vastly, but if it were me, I would use hardened O1 scribes set to make a fine mark. Anything like a pencil or marker will wear enough that it will need to be repositioned rather often.
InstantSiv
#2 posted 03-14-2015 03:18 AM
Hopefully the drawing is easy to understand.
It doesn’t need to be a line. For example I was thinking about a punch at each location but it would probably be hard to see the punch marks.
View Don Broussard's profile
Don Broussard
3528 posts in 2218 days
#3 posted 03-14-2015 03:41 AM
Instant—If the pocket holes are the same distance apart, you could make a jig with a piece of scrap and a brad point drill bit or an awl to mark the hole locations.
-- People say I hammer like lightning. It's not that I'm fast -- it's that I never hit the same place twice!
InstantSiv
#4 posted 03-14-2015 05:50 PM
I tried an awl(screw and hole punch) but the holes are not noticeable enough for me. I’ll try something bigger like a brad point like you suggested. Thanks.
