Plastic for router table, how smooth does it need to be.
Forum topic by scribble posted 03-13-2015 05:13 PM 809 views 0 times favorited 6 replies Add to Favorites Watch
View scribble's profile
scribble
146 posts in 2108 days
03-13-2015 05:13 PM
I am looking to find a place to locate a place to be able to purchase smooth laminate sheets to laminate some MDF for a new router table top.
-- If you can't read it Scribble wrote it!! “Experience is merely the name men gave to their mistakes.”
MrUnix
6359 posts in 2106 days
#1 posted 03-13-2015 05:15 PM
They have it at the BORG.
View bondogaposis's profile
bondogaposis
4611 posts in 2258 days
#2 posted 03-13-2015 05:53 PM
I got mine a Home Re-Source store. They had a lot of smaller pieces left overs from a cabinet shop. Perfect for shop furniture and cheap.
-- Bondo Gaposis
4883 posts in 2400 days
#3 posted 03-13-2015 06:11 PM
If there is a Habitat Re-Store around they will have some of the same kind of scraps that are perfect for this. My store gets $5 each for the pieces, some of them are full sized sheets with a damaged corners or a split on one end.
View DrDirt's profile
DrDirt
4421 posts in 3649 days
#4 posted 03-13-2015 06:22 PM
One other thing to consider, I got melamine coated plywood. It is used for concrete forms
I got it from ‘Home Depot Supply’ which is a contractor version of home depot.
The one in KC is called White Cap Supply
it is 19mm thick (3/4) 4X8 and I paid 42 dollars 2 years ago
Great stuff, slippery, and glue doesnt stick and very rigid… basically Baltic Birch with a skin.
Description
Phenolic Plywood, 19 mm Thick, 4 ft Width, 8 ft Length
Features
Abrasion resistant super long life chemically resistant
Little or no form release needed
Specifications
Type: Phenolic
Thickness: 19 mm
Length: 8 ft
Width: 4 ft
scribble
#5 posted 03-16-2015 07:34 PM
So I went to Menards at lunch looking at there laminate and every sheet there was a granite looking and it was not glass smooth like I was expecting. It wasn’t overly rough but seemed like a car surface that has contaminates on it. Maybe I am just being picky but I thought it would be a problem to use this they way it was.
scribble
#6 posted 03-16-2015 07:49 PM
How much should I expect to pay for this?
