Best method to make dogholes?
Forum topic by deadherring posted 03-13-2015 02:20 PM 1451 views 0 times favorited 19 replies Add to Favorites Watch
View deadherring's profile
deadherring
63 posts in 1672 days
03-13-2015 02:20 PM
Hi,
What’s the best method to make dogholes in a new workbench? The bench is 2×4’s turned on end, so I dont think my plunge router will plunge deep enough to get through it.
If I use a hand drill, do I need to get one of those jigs for hand drills to drill straight holes or is it not necessary?
Also, should I round over/chamfer the holes once I am done? What router bit is recommended? The hole sizes will be 3/4”.
Thanks,
DH
19 replies so far
View jmartel's profile
jmartel
7959 posts in 2179 days
#1 posted 03-13-2015 02:29 PM
I just used a hand drill. No jigs used or anything. Just eyeballed it. And I used a chamfer bit for my router with a bearing. Any would work since you’re only chamfering a small amount. Maybe 3/16” down.
View Sparks8286's profile
Sparks8286
72 posts in 1518 days
#2 posted 03-13-2015 02:55 PM
a hand drill with a forstner bit.
-- If you can't fix it with a hammer, you have an electrical problem.
View Ghidrah's profile
Ghidrah
667 posts in 1251 days
#3 posted 03-13-2015 03:02 PM
If you can get to a DP you can make yourself some drill blocks, I glued pine sections together 1 1/2 and 2” high then drilled into them while clamped to the DP table. I bored a series of holes in a spiral pattern to increase the number of bit diameter options. Even though it’s pine they seem to be lasting.
-- I meant to do that!
View handymensch's profile
handymensch
1 post in 1199 days
#4 posted 03-13-2015 03:38 PM
3/4” Forstner bit. Easy. To avoid tearout on the underside, only drill half-way through the top, then take a smaller drill bit and drill through the pilot hole left by the Forstner bit. Then flip the bench over (I know, easier said than done) and line up your Forstner bit with the pilot hole. Done.
View bondogaposis's profile
bondogaposis
4770 posts in 2380 days
#5 posted 03-13-2015 04:08 PM
When I did my bench, I used the plunge router to start the holes. The I finished them w/ an auger bit. I used a chamfer bit w/ a bearing to chamfer the holes.
-- Bondo Gaposis
View Tim's profile
Tim
3812 posts in 1990 days
#6 posted 03-13-2015 05:28 PM
I’ve heard people talking about dog holes needing to be accurate, but I honestly can’t figure out why. I can’t think of anything that a dog hole is used for that really matters if it’s 1 degree off. But because people talk about making them accurate I used the standard hand tool method to drill accurate holes with a brace and bit and put two try squares at 90 degrees to each other to use to sight along the bit to make sure I was going in square. You could do the same thing with an auger bit and a power hand drill just stop quickly while you can adjust and go from there. I haven’t measured, but I’m sure I’m less than 1 degree off on each hole.
Found the video that shows the method I was talking about:
https://www.youtube.com/watch?v=TgUNSduft0A
View Mykos's profile
Mykos
103 posts in 1823 days
#7 posted 03-14-2015 12:03 AM
I used a brace with an auger bit. Here a good trick by Richard Maguire for drilling square.
deadherring
#8 posted 03-15-2015 02:48 AM
Thanks all for the advice. Sounds like it’s easier than I think. Just a quick follow up: can I drill all holes all the way thru if I want to use any hole for a doghole or a holdfast or do the dogholes have to not be all the way thru in order to stay in place? If it matters the dogholes I bought are from lee valley.
bondogaposis
#9 posted 03-15-2015 04:09 AM
Dog holes need to to be all the way through otherwise they fill w/ sawdust and you need to be able to push the dog up from the underside and they double as holdfast holes that way too. I thought Lee Valley only sold dog holes on April 1st.
-- Bondo Gaposis
Mykos
#10 posted 03-15-2015 04:30 AM
I would not consider having blind holes in the benchtop. As bondo says, it’ll just fill with chips and dust and it’ll be awful trying to get things out. The Veritas dogs have a metal spring along the side to keep them in place, even in oversized holes.
View rwe2156's profile
rwe2156
2967 posts in 1509 days
#11 posted 03-15-2015 01:13 PM
I used a spade bit. Probably should have started the hole with a Forstner. But since I knew I was going to flatten the top anyway, the tear out was removed.
I used a couple squares to keep me lined up, but in retrospect, I would make some kind of guide.
Some dogs like LV’s “pups” don’t need through holes, but you’ll have to blow them out once in a while.
I would do through holes because then you can use a bench hook.
View benchbuilder's profile
benchbuilder
284 posts in 2479 days
#12 posted 04-07-2015 12:40 PM
When you drill your dog holes, clamp a 2×6 to the bottom side of the bench where the dog holes pass through. Put clamps on from the outside edge of the top and along the length of the 2×6 to keep it tight to the bottom of the top, this will help or even prevent tear out on the bottom side of the dog holes as you drill through the bench top and into the 2×6.. i made a drill jig of 2×4 with a 3/4” bronze bushing in it andclamped to the top as i drilled. This also helps keep the holes striaght.
deadherring
#13 posted 04-07-2015 01:33 PM
I ended up using a spade bit and a drill bit extender to get all the way through. It worked well, but I wish I would have seen benchbuilders advice beforehand since I got some bad blow out on the underside. But, no one will ever see it so its ok.
View BroncoBrian's profile
BroncoBrian
556 posts in 1987 days
#14 posted 04-07-2015 02:38 PM
I used a brace with an auger bit. Here s a good trick by Richard Maguire for drilling square.
- Mykos
Excellent and simple technique for getting those holes straight. So much better than the jigs I have seen. Most of what I have seen is flimsy and could not possible work as well as this.
Thanks for posting.
-- I think foosball is a combination of soccer and shish kabobs.
View timbertailor's profile
timbertailor
1594 posts in 1453 days
#15 posted 04-07-2015 03:58 PM
I suggest using a drill guide and a straight edge.
