Rewiring DC to 220V. Comments?
Forum topic by BANick posted 06-10-2009 01:20 AM 992 views 0 times favorited 5 replies Add to Favorites Watch
View BANick's profile
BANick
53 posts in 3850 days
06-10-2009 01:20 AM
Topic tags/keywords: question
Hi All,
I just treated myself to a brand new Delta 50-760 (on sale at amazon.com btw). It’ll be nice to not have to empty the shopvac after every few board feet through the planer.
My shop is in the garage and I only have one 110V circuit in which all the tools are plugged in and an unused 220V circuit. I am thinking about rewiring the DC for 220V since plugging it in the 110V circuit will probably trip the breaker when I also turn another tool on.
Do you have any comments/experience in rewiring this kind of machine? I don’t see any diagram in the doc. If you have done this on your machines, did you also change the switch?
Thanks
Nick
-- Nick, Fremont, CA.
5 replies so far
View kerflesss's profile
kerflesss
182 posts in 3331 days
#1 posted 06-10-2009 01:43 AM
Whats that 220 circuit look like; Small or large outlet; Whats the amperage of the breaker?
Delta recommends a 20amp circuit. The diagram is on the inside cover of the motor. You will need to change the plug as per your manual.
TopamaxSurvivor
18244 posts in 3639 days
#2 posted 06-10-2009 01:43 AM
There should be a diagram inside the motor connection plate if it is convertible to 220. Be sure to use appropriate cord caps and receptacles :-))
BANick
#3 posted 06-10-2009 01:47 AM
Kerflesss,
It’s the small outlet type, on a 20A breaker. Do you think the switch needs to be changed as well or is it just a matter of wiring the motor properly and changing the plug?
View Sawdust2's profile
Sawdust2
1466 posts in 4051 days
#4 posted 06-10-2009 02:19 AM
Just mke the plug and outlet match and change the wire.
I did it. It reallly is a no brainer to do.
You are right about blowing the circuit if you don’t.
BANick
#5 posted 06-10-2009 05:19 AM
Thanks for your help, guys. Will give it a try soon.
