Forum topic by tresselk | posted 06-09-2009 08:59 PM | 2070 views | 0 times favorited | 6 replies | ![]() |
I am using the Fein Multimaster tool for the first time. I am trying to use the profile sanders, but am not having any luck. The clamp attachment that accomadates the different profile sander doesn’t seem to hold the sanders. The quick detach feature makes it easy to switch tool. I have not problem with that. However, when I put the rubber sanding profile and the sandpaper into the clamp attachment for it, the rubber profile sander comes out. It seem sturdy when the machine is off. But it’s not too long after turning the tool on and starting to sand that the profile sander comes loose from its clamp attachment. Can anyone tell me what I am doing wrong?? Thanks |
