Buying Lumber
Forum topic by Yettiman posted 173 days ago 302 views 0 times favorited 7 replies Add to Favorites Watch
Rockler
View Yettiman's profile
Yettiman
153 posts in 638 days
173 days ago
Topic tags/keywords: resource question cherry milling
Hi,
I am looking to buy some lumber in the rough, how much will I loose when I plane down the boards please?
I mean how thick will the final board be from a 1” and a 1.5” board?
Many Many thanks
-- Keep your tools sharp, your mind sharper and the coffee hot
View Julian's profile
Julian
698 posts in 425 days
173 days ago
Typically you will loose around 1/8”-1/4” after jointing/planing. An 8/4 (2” thick) board will yield around 1 3/4”, while 4/4 (1” thick) generally yields 3/4”-7/8”.
-- Julian, Park Forest, IL
View PurpLev's profile
PurpLev
2763 posts in 548 days
173 days ago
it really depends on how twisted the rough board is, and it’s irregularity on the surfaces… if it’s fairly straight, and ‘normal’ expect to take off ~1/4”
View HokieMojo's profile
HokieMojo
1142 posts in 628 days
173 days ago
also, shorter boards are less impacted by small defects. a warp or cup in a board that is many feet long might be impossible to straighten. One trick is to cut most of your boards to rough lenght before jointing/planing if your goal is to keep lumber as thick as possible.
View sikrap's profile
sikrap
212 posts in 259 days
173 days ago
Depending on your planer, I would also cut the boards 4-6 inches longer than what will be needed to allow for snipe. Of course, if you don’t have a snipe issue, there is no need. Good Luck!!
-- Dave, Colonie, NY
View closetguy's profile
closetguy
310 posts in 792 days
173 days ago
When you choose your boards, look for the ones with the least cupping. The greater the cup (side to side bow), the more you will have to plane to get it flat. The best case scenario is 1/8” reduction after planing both sides. I’ve had some that it took 1/4” or more to get it flat. My lumber supplier brings rough boards out on a pallet and I dig through all of the boards until I find the best ones for my application.
-- I don't make mistakes, only design changes....www.dgmwoodworks.com
View pommy's profile
pommy
977 posts in 591 days
111 days ago
Hi Yettiman
Where do you bye your lumber from if from a sawmill like me most of the furniture timber is usually a very good grade so you shouldn’t lose that much if you bye what i call proper rough timber then you should look to lose about 10 to 15mm but it really does depend on the grade your bying …........
ANDY
-- cut it saw it scrap it
Yettiman
110 days ago
Many thanks guys – much appreciated
I’ll let you know how it turns out
1st major project :)
