Improving a workmate?
Forum topic by AESamuel posted 03-12-2015 04:47 PM 6289 views 0 times favorited 10 replies Add to Favorites Watch
View AESamuel's profile
AESamuel
73 posts in 1126 days
03-12-2015 04:47 PM
Hi,
I have a Black and Decker Workmate 536 as my primary workbench as I don’t have a shop, I just do woodworking in the front room of my apartment. (don’t worry, the neighbours are fine with it as I use mainly hand tools!)
I’m just wondering if anybody has made any improvements or has any ideas on improving a workmate? I would like another 6-8” height on the bench while improving/keeping the stability. Being able to fold the bench flat is great, so the modifications mustn’t take more than about 20 minutes to take off so I can still store it away in the cupboard.
I was thinking of adding a small 6” vice to the table which would be easier to use than the “moxon” style already on the workmake, but I’m worried that with such a thin table on the workmate the vice would rock and make planing tricky.
So, any thoughts would be greatly appreciated, or even alternatives to the workmate!
Thanks,
Asa
10 replies so far
View Richard H's profile
Richard H
489 posts in 1584 days
#1 posted 03-12-2015 04:55 PM
I had one on a deck workshop for a time and I found for hand tool work it wasn’t heavy enough or stable enough for planning. I ended up taking two saw horses and clamping 4X4’s between them on the lower shelf to build a more stable bench which only worked slightly better. Maybe you could do something like that under the feet that would both raise the height and stabilize it some. Something like take a couple 4’ long 4X4’s and attach them to the feet somehow to widen the base.
Take a look at the Milkman workbench by Chris S. in Popular Woodworking if you have not already. It’s a good option for in house or deck based woodworking especially if you build a base for it. I was working on one with a splayed leg base that could be broken down before I ended up moving that I’ll get back to finishing someday.
Something like combining this.
http://www.popularwoodworking.com/workbenches/schwarz-workbenches/the-milkmans-workbench-in-use
with this.
http://www.wkfinetools.com/contrib/wMyers/moravianBench/moravianBench-01.asp
Good luck.
View HarveyM's profile
HarveyM
99 posts in 1926 days
#2 posted 03-12-2015 05:01 PM
Here’s my contribution to the ‘workmates of our dreams’ thread:
https://s3.amazonaws.com/vs-lumberjocks.com/nd19hxm.jpg
-- Just a Duffer
View Oughtsix's profile
Oughtsix
42 posts in 1078 days
#3 posted 03-12-2015 05:23 PM
I have a 40×40 shop with a wood working bench. I also have 3 workmates of various vintages and use them a lot!
I have replaced the tables on most of them (bought them used with beat up tables) with home made hardwood tables. That is a nice upgrade.
The height on Workmates is a compromise. An extra 6” would be nice but it doesn’t seem like it would be an easy addition. Maybe you could make a wooden box to store the Workmate in when not in use then the box becomes a base to raise the workmate up 6” when it is in use? Just a thought.
If your are going to add a vice to the top of the workmate I would mount the vice on a board then clamp the board into the workmate. Should be sturdy and quick to disassemble.
Black and Decker used to make some great toggle clamps for the workmates. Unfortunately they have discontinued them. They are the best accessory for the workmates that I have. If you pick up a used pair make sure you get the orange plastic shrouds with them. The clamps are worthless without the orange shrouds.
http://kirkhmb.smugmug.com/Woodworking/Workmate-Type-Study/5539701_TNtt7z/1088956144_DTxzhTq#!i=1088956144&k=DTxzhTq
View ChefHDAN's profile
ChefHDAN
1010 posts in 2753 days
#4 posted 03-12-2015 07:39 PM
Sam, some good Workmate posts & info on this LJ thread
I’ve got three and there is always at least one in use at all times as a roll around table.
View nmssis's profile
nmssis
139 posts in 889 days
#5 posted 10-02-2015 02:17 AM
Hi,
I have a Black and Decker Workmate 536 as my primary workbench as I don t have a shop, I just do woodworking in the front room of my apartment. (don t worry, the neighbours are fine with it as I use mainly hand tools!)
I m just wondering if anybody has made any improvements or has any ideas on improving a workmate? I would like another 6-8” height on the bench while improving/keeping the stability. Being able to fold the bench flat is great, so the modifications mustn t take more than about 20 minutes to take off so I can still store it away in the cupboard.
I was thinking of adding a small 6” vice to the table which would be easier to use than the “moxon” style already on the workmake, but I m worried that with such a thin table on the workmate the vice would rock and make planing tricky.
Thanks,
Asa
- AESamuel
the workmate that you have is an older model? I’m considering picking up the latest 425 model…and I realize that the frame is not as sturdy as older models.
Since I’m in a same boat as you in terms of available space Workmate seems to be my only option. But the question is the table sturdy enough for running hand planning?
Thanks!
-- Learn something new everyday!
ChefHDAN
#6 posted 10-02-2015 03:56 PM
nmssis,
The older workmates are very sturdy and heavier than the ones currently sold, they turn up on Craig’s list frequently and can be had for $20 to $30. As for using a hand plane you’ll be limited to boards not much longer than the WM top as it’ll want to tip if you’re doing a 6’ board. I just finished some inset cabinet doors and needed to tweak them to fit the openings and very easily planed the 20”x20” doors with a WM.
So the answer is yes & no but depending on your project you can make it work, I have 4 WM’s now and they meet the uses I have for them very well, but I’d love to have a leg vice and a wagon wheel with some dogs… but that will have to wait for the next shop.
nmssis
#7 posted 10-02-2015 08:13 PM
nmssis,
The older workmates are very sturdy and heavier than the ones currently sold, they turn up on Craig s list frequently and can be had for $20 to $30. As for using a hand plane you ll be limited to boards not much longer than the WM top as it ll want to tip if you re doing a 6 board. I just finished some inset cabinet doors and needed to tweak them to fit the openings and very easily planed the 20”x20” doors with a WM.
So the answer is yes & no but depending on your project you can make it work, I have 4 WM s now and they meet the uses I have for them very well, but I d love to have a leg vice and a wagon wheel with some dogs… but that will have to wait for the next shop.
- ChefHDAN
Thanks for the reply.
I won’t be building or planning any stock longer than 28×4 x 4 or 20×16 x 2 n such…so i guess for my limited space and budget, it may do for now.
View bandit571's profile
bandit571
19172 posts in 2587 days
#8 posted 10-02-2015 09:24 PM
This was a freebie
Currently using the “dogs” as such on my workbench….this one is just holding a few items for me
Even a plane till. The wooden parts need replaced, someday. Need more of them plastic dogs….
View MT_Stringer's profile
MT_Stringer
3153 posts in 3134 days
#9 posted 10-02-2015 10:11 PM
The height on Workmates is a compromise. An extra 6” would be nice but it doesn t seem like it would be an easy addition. Maybe you could make a wooden box to store the Workmate in when not in use then the box becomes a base to raise the workmate up 6” when it is in use? Just a thought.
+1 What he said.
Clamps are cheep at Harbor Freight. I use them a lot.
Another option would be to build a separate portable work table like this one. I built it several years ago. Pretty useful.
View OleGrump's profile
OleGrump
158 posts in 248 days
#10 posted 08-04-2017 12:25 PM
Please check the “Workmates Of Our Dreams” thread here on Lumberjocks. I posted some photos yesterday of a device/application which will probably be of use to you. They’re marked as posted by Ole Grump. Hope it helps.
-- OleGrump
