Aligning a drill press
Forum topic by botanist posted 172 days ago 308 views 0 times favorited 8 replies Add to Favorites Watch
View botanist's profile
botanist
44 posts in 436 days
172 days ago
My drill press is missing the gearing for raising and lowering the table, so I need to do it manually. In the process of moving the table up or down, I’m thinking that the table gets out of alignment with the chuck. I have a sliding fence on my sacrificial table that I can align on the table using a square, but I wasn’t sure if I needed to realign the table relative to the chuck. If I do, does anyone out there have any easy way to accomplish that?
View kerflesss's profile
kerflesss
132 posts in 265 days
172 days ago
Delta uses a simple steel pin inserted in the chuck and squared left to right and front to back.
View TopamaxSurvivor's profile (online now)
TopamaxSurvivor
3053 posts in 573 days
172 days ago
tie a plumb bob on a drill bit or pin in the chuck.
View niki's profile
niki
429 posts in 977 days
172 days ago
I hope that this post will solve your problem
http://lumberjocks.com/topics/446
And, if you are already around, have a look at those posts
http://lumberjocks.com/topics/952
http://lumberjocks.com/topics/1196
Regards
niki
View marcb's profile
marcb
705 posts in 571 days
172 days ago
realign it how? As you are referencing a single point unless the table tilts it doesn’t matter in terms of a little to the left or right
TopamaxSurvivor
171 days ago
Those are great posts Nikki, Love your ideas.
botanist
171 days ago
Thanks for the great ideas, Niki, those should help quite a bit, but I’ll need to figure out how to make it work with my drill press. My drill press is a floor model so I wouldn’t be able to clamp a straight edge to the base to help with alignment.
To clarify my problem, I’ve started working on a new workbench and I needed to cut some mortises in a 4×4 using a forstner bit, since I don’t own a good set of mortise chisels. I ran into a lot of problems when I was trying to cut left to right since my alignment was so wacky. Since I only have about 3 inches of travel in my press, I had to flip the stock over to complete the process and I had to realign the drill press.
TopamaxSurvivor
171 days ago
For lack of a better way, transfer your layout around the post with a square.
kerflesss
171 days ago
You might consider doing you mortise with a router and a jig. Finish fine tuning by hand with a chisel.
http://www.woodworkersguide.com/2008/03/03/a-simple-plunge-router-mortising-jig/
