table saw left or right tilt
Forum topic by daddywoofdawg posted 03-12-2015 01:34 PM 987 views 0 times favorited 4 replies Add to Favorites Watch
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1478 days
03-12-2015 01:34 PM
Topic tags/keywords: tablesaw
I have been looking at table saws and see table saw left or right tilt.which is the preferred?what does it mean other than the blade tilts one way or the other,does that mean the direction the top of the blade leans when tilted I.E / right tilt, \left tilt?
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1079 days
#1 posted 03-12-2015 01:40 PM
Most people consider a saw blade that tilts toward the fence as more dangerous and it is harder to make certain type of cuts.
View knotscott's profile
knotscott
7871 posts in 3278 days
#2 posted 03-12-2015 01:47 PM
FWIW, most of the newer saws are left tilt. There are pros and cons to both which many feel are minor concerns, and it really boils down to a matter of preference. On Left tilt saws the blade bevels away from the fence with the fence on the right of the blade (standard location), which is considered safer. Right tilt bevels toward the fence on a standard bevel cut, which is considered less safe than if it beveled away from the fence. You can move the fence to the left of the blade for safer bevel cuts, but that makes it a non-standard operation, which is still not quite as safe as a bevel cut on a left tilt saw.
The downside of a left tilt saw is that any changes in blade thickness will skew the zero reference on the tape measure because the left side of the blade registers on the right side of the flange (the same direction as the tape measure reads). This can be adjusted by recalibrating the cursor, always using blades of the same thickness, using shims as spacers, or just measuring by hand. Blade thickness changes make no difference with a right tilt saw because the right side of the blade registers against the left side of the flange, so changes in blade thickness don’t impact the tape measure.
Here’s another difference that will also be a matter of preference. The arbor nut on a right tilt saw gets applied from the left side of the blade and uses a reverse thread orientation, which is typically done with your left hand. The arbor nut on a left tilt saw goes on from the right side (easy for right handers) and uses a normal thread orientation.
4872 posts in 2396 days
#3 posted 03-12-2015 02:40 PM
It’s strictly a matter of personal preference, and Scott’s comments are right on. There was a time when left tilt saws weren’t all that common, but they have caught fire over the last 10-15 years.
View BurlyBob's profile
BurlyBob
5239 posts in 2168 days
#4 posted 03-12-2015 03:51 PM
Scott has nailed it down for you. One thing I had overlooked was the blade thickness issues. A very valuable point to remember in the future. Thanks Scott!
